kansas buckeye
Is there a easy way to replace the roller pin in the steering column on a 854
kansas buckeye
Is there a easy way to replace the roller pin in the steering wheel of a Wheelhorse 854
BOB ELLISON
:text-welcomeconfetti:
There is a lot of posts here about trying to remove that pin . It can be a real problem sometimes trying to remove it.
Start with a good penetrating oil and spray it for a few days .
Go to the main page and search for steering wheel pin there's over 450 posts on how to do it.
This may help
Edited by BOB ELLISON
rmaynard
The most important thing is that when you are tapping the pin out with a roll pin punch and hammer, that you have a solid, unmovable object behind it acting as an anvil. If the steering wheel or shaft moves even the slightest, the power of the punch is reduced to almost nothing and the pin won't move.
  • Like 5
  • Excellent 1
Achto
If it will not drive out with a punch & hammer, a 1/4" carbide drill bit will be the only thing that will drill it out.
rjg854
An air hammer and roll pin bit works pretty well if you have access to one, I borrowed one from Squonk and it was  so easy.
Racinbob
You can park it next to a tree and cut a 2x4 to length to wedge between the tree and steering column to get the support rmaynard is talking about. :)
  • Like 3
  • Thanks 1
JERSEYHAWG /  Glenn
PB blaster helped me, but it was a fight. Read others posts, plenty of information on it.
Glenn
  • Similar Content
    • 2003Chevy
      By 2003Chevy
      Hello All!
      Added THREE tractors all at once yesterday(09/16/2025).  Two model 854, and one model 855.  The two 854 look pretty nice, but are not running right this minute  --does not look like much more than a little tinkering/refreshing after sitting for a long time.  The 855 was labelled a "parts" tractor, but except for it being Really well-used looking, it seems to be all there so I am not going to consider it out of play yet.  The two 854's have rear discharge mower  decks...one is a square style deck, the other the rounded style deck.
      I think it is really nice that all three are basically the same machine, separated by one year, yet completely different styles--the end of one era and the beginning of another I guess.
      There is an ID tag on the 855 (serial number 135166) but on the two 854 tractors, there is No tag under the steering like late models.  Are the tags in a different place on older machines?  Looking them over, I do not notice anything obvious.  The 854 with the lower Kohler engine serial number has the round style mover deck, while the one with the slightly higher engine serial number has the square style deck.
      All for now!  Be well and stay safe.
      [rayg]
    • dlashb40
      By dlashb40
      As a retired 61-year-old who inherited 4 of my Grandfather's Wheel Horse tractors, I found a valuable resource in this forum. Here, I connected with Bob Parks (Racinbob), who at the time lived nearby and kindly agreed to help me identify all of them. I ended up keeping the 1964 Model 854 and sold the others. The 854 is a solid, primarily original tractor, and I've been using it since I was 6-years-old. I also had the RM-364 mower deck attachment, which had not been on the tractor for many years. Once again, this forum proved its worth as I could identify and obtain some attachment parts that I was missing. Last week, after some adjustments, I put the mower deck to use and mowed nearly an acre of grass without any issues. The sense of accomplishment in identifying and restoring the equipment was truly inspiring, and I felt like I was a kid again.
      As someone who doesn't consider themselves 'mechanically inclined,' I've grown and learned much through this project. I want to express my heartfelt thanks to all of those who guided me and showed me that with the right support, even the most daunting tasks can be tackled.
    • Bodean
      By Bodean
      In search of bottom plate for 854 two pieces tank mine is cracked will take whole tank if one is available i have a replacement gasket already thanks
    • Bodean
      By Bodean
      Slow but sure turning the corner get big red back together waiting on transmission seals
    • rustyedge1
      By rustyedge1
      These belts have been hanging in my garage since last used I believe there off a 754 I used to have. Bought them new and didn't use much.
      Don't know why I took them off. Some fraying on top in a few places from use, also don't know why but selling as is and photo'd. 20.00 shipped if you can use them.
      PM for PayPal info or questions. 16" ID approx.
