bumpsteer 38 #1 Posted June 11, 2018 Owner says this is a 516H. Is it? Comes as it is, has leak in Hyd system, not sure which pump it has. Give me an idea of a fair prie please. Doug Share this post Link to post Share on other sites
T-Mo-(Moderator) 4,752 #2 Posted June 11, 2018 No, it's not a 516-H, unless every piece of sheet metal, including the pedestal was changed. 2 Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,005 #3 Posted June 11, 2018 Not a 516-H which is a 1988 model. The photo is a 1976 or 1977 C120 Automatic or C-160 Automatic model. Garry Adding No holes in the hood for the ornament used on the 1975 models Narrow hood stand - wide started in 1978 when the fuel tank was moved to under the seat 1 Share this post Link to post Share on other sites
953 nut 64,142 #4 Posted June 11, 2018 (edited) As Garry said it appears to be a mid '70s and would probably have a value of $ 350 +/- Take a look at the 416 listed in our classifieds, same tractor for all intents and purposes. Edited June 11, 2018 by 953 nut ad for 416 Share this post Link to post Share on other sites
bumpsteer 38 #5 Posted June 11, 2018 Thanks did not think it was but wanted to check since I am knew at this WH thing. Doug Share this post Link to post Share on other sites
Ed Kennell 44,912 #6 Posted June 11, 2018 Based on the smaller motion control knob, it has to be a 75-77 C-120 or C-160 auto. 74s had the larger screw on knob. With a 3,4, or 500 series seat mount. Share this post Link to post Share on other sites
bumpsteer 38 #7 Posted June 11, 2018 Makes since seat was changed does have the 16 hp. I ask for the ser. # and he said tag had been removed only rivet holes left. Doug Share this post Link to post Share on other sites
dcrage 631 #8 Posted June 13, 2018 For what it is worth this tractor has a better hydraulic transmission combination than a 516-H. The 516 had Eaton 700s which are NOT rated for “ground engaging” attachments. The mid ‘70s Cs had Sunstrands or maybe Eaton 1100. Share this post Link to post Share on other sites
c-series don 11,387 #9 Posted June 13, 2018 What everybody says here is correct. Basically the only thing that tractor and a 516 H is the tire size ! Share this post Link to post Share on other sites
