WH654 23 #1 Posted June 9, 2018 I just bought a Raider 12 and i have to hold the throttle control out to keep the rpm's up is there a way to fix this? Share this post Link to post Share on other sites
953 nut 62,119 #2 Posted June 9, 2018 You can find new ones on Ebay or you can use a spring loaded cloths pin. 1 1 Share this post Link to post Share on other sites
wallfish 18,625 #3 Posted June 9, 2018 The old push/pull throttle cables have a twist lock. Turn to the right and they lock in position. Yours may have been replaced, it got stripped out or isn't turning. If you need a new one search for locking throttle control Share this post Link to post Share on other sites
pfrederi 18,966 #4 Posted June 9, 2018 11 hours ago, 953 nut said: You can find new ones on Ebay or you can use a spring loaded cloths pin. 1 clothes pin fast idle 2 clothes pins full throttle...I have 2 or 3 horses that use this method. Throttle cables are not cheap. 1 Share this post Link to post Share on other sites
CasualObserver 3,411 #5 Posted June 9, 2018 Your problem might be that the knob is spinning on the throttle control and not turning the lock. You can try glueing the knob, it may work. I just clamped a tiny pair of vice grips to mine and it makes a nice easy grip lever for locking and unlocking the throttle. Share this post Link to post Share on other sites
WH654 23 #6 Posted June 9, 2018 Thanks Fellas i ordered a new cable assembly. Share this post Link to post Share on other sites
WH654 23 #7 Posted June 16, 2018 The new throttle assembly works great. Thanks again! 2 Share this post Link to post Share on other sites
