dmill_theredneck 1 #1 Posted June 5, 2018 I have a wheel horse 18 automatic blew the front crank seal so I took the motor out and replaced that and the front cover gasket and the gasket on the other round gasket that the points are in and now my imagination timing is off could someone please explain to me how to ignition time the motor please all.I'm getting is backfiring out of the exhaust thanks you Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,722 #2 Posted June 5, 2018 Service manual help? Garry Share this post Link to post Share on other sites
dmill_theredneck 1 #3 Posted June 5, 2018 Thank you I was hoping someone had one Share this post Link to post Share on other sites
a.dumont 10 #4 Posted June 9, 2018 Static base timing between the governor and camshaft gear is pretty straight forward. Don't forget to clean and adjust the point gap, and then use a timing light to set the dynamic timing. (Procedure in the manual.) Share this post Link to post Share on other sites
