Wheelhorseking 0 #1 Posted June 4, 2018 I need help so I got the 1056 wheel horse I got it to run but it have a very weak low idle but it acts like it wants to idle up what do I need to do please help Share this post Link to post Share on other sites
953 nut 63,922 #2 Posted June 4, 2018 A few basic tune up steps should get you fixed up. I would begin with a refreshing of the fuel system, gas line, fuel filter and carburetor cleaning. Be sure to use ethanol free gas. Also a new Champion H-10 spark plug and points and condenser would be a good idea. One thing we ask of all new members, 2 Share this post Link to post Share on other sites
Wheelhorseking 0 #3 Posted June 4, 2018 how do I refresh the fuel system Share this post Link to post Share on other sites
953 nut 63,922 #4 Posted June 4, 2018 Rebuild the carburetor, replace the fuel lines and fuel filter. 1 Share this post Link to post Share on other sites
Wheelhorseking 0 #5 Posted June 4, 2018 Would starting fluid help? Share this post Link to post Share on other sites
953 nut 63,922 #6 Posted June 4, 2018 Do not use starting fluid. The ether is so volatile that it could harm the engine. If you want to add anything to the gas I would suggest SeaFoam. Chances are it may help but nothing will replace doing the job right the first time. 2 Share this post Link to post Share on other sites
rmaynard 16,837 #7 Posted June 5, 2018 And when you do get it running right, Kohler recommends a slow idle speed of 1100-1200 rpm. Anything slower and you will not be getting proper lubrication. 1 Share this post Link to post Share on other sites
Wheelhorseking 0 #8 Posted June 5, 2018 My throttle control is hard to pull and push I. How do I fix that Share this post Link to post Share on other sites
953 nut 63,922 #9 Posted June 5, 2018 27 minutes ago, Wheelhorseking said: My throttle control is hard to pull and push I. How do I fix that If it has not been kinked you may be able to put some PB Blaster or the penetrating oil of your choice in both ends and free it up. Otherwise you can find new replacement cables on ebay. Share this post Link to post Share on other sites
Wheelhorseking 0 #10 Posted June 5, 2018 The choke is hard to pull and push to Share this post Link to post Share on other sites
wallfish 19,067 #12 Posted June 5, 2018 If it will idle but not throttle up at all, a possible cause is the condenser. It should be connected to the - side of the coil. If it is on the - side a replacement isn't very expensive. Share this post Link to post Share on other sites
