MS GENERAL REPAIR 17 #1 Posted June 2, 2018 Video Series covering rebuilding the carburetor on a 2006 Kohler CH20S 1 Share this post Link to post Share on other sites
MS GENERAL REPAIR 17 #2 Posted June 2, 2018 Here is part 1B of the series 1 Share this post Link to post Share on other sites
Kurt-NEPA 756 #3 Posted June 2, 2018 Nice videos. I found the other two on You Tube. Always good to see detailed tear down and build up videos on critical pieces of equipment. I have two of these carb on my 5xi's. You said you used an ultrasonic cleaner. What media did you use? Thanks for sharing. Kurt Share this post Link to post Share on other sites
MS GENERAL REPAIR 17 #4 Posted June 2, 2018 Right now my ultrasonic has Zenith #251 clock cleaning solution in it. It works pretty well on carburetors. I'm going to try Blaze Off by Birsch. I've been using Blaze Off for 15 years as a cleaner/de-greaser in an atomizer bottle. it works pretty well and is easy on your lungs. My ultrasonic cleaner is a heated model, so FLASH POINTS of products is always a concern. Some Cleaners I could use at room temperature, I would never put in my ultrasonic. Share this post Link to post Share on other sites
Kurt-NEPA 756 #5 Posted June 2, 2018 I've been using some NAPA carb cleaner in a one gallon can. Works well if you let the carb sit for a day or two. I was wondering if it would work in an an ultrasonic unit. Yours is heated, don't think I would try that. Might be a cheapy ultrasonic cleaner in my feature. Thanks for the the info. Kurt Share this post Link to post Share on other sites
MS GENERAL REPAIR 17 #6 Posted June 3, 2018 Here is part 2A 1 Share this post Link to post Share on other sites
