Red144runner 659 #1 Posted May 31, 2018 Took the tractor and new used sheet metal to work today. Had some time so I started taking parts off. The fender is real bad. Years of letting grass build up and time in the rain have rotted it out. Had to grind a few bolts here and there. The pto side running board was replaced with a piece of 3/16" diamond plate with tubes welded on under neath to slide over the mounting rods. Done quite well too. The hydro filter mount is broken from frame (new one ordered). It's gunked up good but aside from the sheet metal it's solid. Drained trans today too. 4 Share this post Link to post Share on other sites
953 nut 70,343 #2 Posted May 31, 2018 You can use sheet metal from any 300 or 400 series if yours prove too challenging. 3 Share this post Link to post Share on other sites
Red144runner 659 #3 Posted June 1, 2018 Luckily I found all the tins I need. Even a 520 hood, the paint is faded a bit but compared to what it has now big improvement Share this post Link to post Share on other sites
Tractor boy 239 #4 Posted June 1, 2018 Umm. I’m at a loss for words. I thought my tractor needed to be cleaned but this one definitely needs it more than mine. Is this going to be a full resto or just a sheet metal patch or replace fix? Share this post Link to post Share on other sites
Red144runner 659 #5 Posted June 1, 2018 Replace all rot, good cleaning/degreasing. Further replacement of parts I'm sure, then tune up and some paint. Final product look good and functional. 2 Share this post Link to post Share on other sites
