Jamie Darian Brown 9 #1 Posted May 30, 2018 Hi, Here is a pic of my solenoid on my B80 that needs replacing. When searching for one online I see ones that show up for a wheelhorse but do not exactly look like this one. Will these "new" ones fit but just look different? Trying to make sure I order right one. Share this post Link to post Share on other sites
Racinbob 11,906 #2 Posted May 30, 2018 If your parts store doesn't have the three terminal you can use a Ford four terminal. Simply ignore the 'I' terminal. 2 1 Share this post Link to post Share on other sites
Jamie Darian Brown 9 #3 Posted May 30, 2018 Here is pic of one online I found... different... but will it change out and work? 1 Share this post Link to post Share on other sites
Jamie Darian Brown 9 #4 Posted May 30, 2018 so the above pic I have of new one online would be the "three" terminal and would work.... though shaped diff..... 1 Share this post Link to post Share on other sites
Racinbob 11,906 #5 Posted May 30, 2018 As long as it's 12 volts it will work great. 2 Share this post Link to post Share on other sites
WHX?? 51,583 #6 Posted May 30, 2018 You should also be able to take your old one into any auto parts store and they will fix you up. 3 Share this post Link to post Share on other sites
953 nut 59,570 #7 Posted May 30, 2018 Your present solenoid may be the problem, or there may be another problem that makes you think there is a bad one. Have you cleaned and tightened all electrical connections including grounds? If you run a small jumper wire from your battery "+" terminal to the small terminal on the solenoid do you hear it close? Just hate to see people buy a bunch of parts only to find that there was another simple fix that could have cured the problem. 2 Share this post Link to post Share on other sites
Jamie Darian Brown 9 #8 Posted June 1, 2018 I tested it like you said. I don't hear it close or click so I assume its bad. Thank for that tip on testing it. And thanks to all for y'alls help! Gotta get it ready to till the garden Share this post Link to post Share on other sites
oldredrider 2,553 #9 Posted June 1, 2018 Solenoids do go bad, but make sure it is well grounded when testing it before writing it off. Share this post Link to post Share on other sites
mike avad 46 #10 Posted July 29, 2024 How can you tell if there bad? Share this post Link to post Share on other sites
953 nut 59,570 #11 Posted July 30, 2024 6 hours ago, mike avad said: How can you tell if there bad? Lets take a logical step by step inspection of your starter problem. Is your PTO in the ON position, a wheel horse will not start with the PTO on. Have you had the battery load tested at an auto parts store? Have you cleaned and tightened all electrical connections including grounds? Are all fuses good and fuse holders cleaned? If these have all been done, we can check components of the starting system as follows; don’t skip a step or you may miss the problem. Be sure the transmission is in neutral and the parking brake is set. Take a pair of automotive jumper cables and connect the black cable to your battery "-" and a good clean spot on the engine. Now connect the other cable to the large post on the starter and touch the other end to the battery "+" terminal, does the starter turn over? If the starter turns over the battery and starter are good. If it didn't turn over try the same steps with the battery in your car/truck, if that cures the problem then the "good" battery wasn't so good. Presuming the starter turned over move the jumper wire from the starter post to the other end of the wire going to the starter which is one of the large posts on the solenoid. If the starter turns over when the battery is touched by the jumper as before then that cable is good, if not you have found your problem. Presuming the starter turned over move that jumper to the other terminal of the solenoid, connect the other end to the battery and use a small piece of wire to temporarily connect the battery "+" terminal to the small terminal on the solenoid, this should cause the solenoid to close and the starter to turn over. If not, the solenoid is probably the problem. If this was successful remove the large jumper cable and use the small jumper wire to the small terminal of the solenoid, the solenoid should close and the starter turn over. If not the cable to the battery is the problem. Presuming all of these have been successful remove the black jumper wire and repeat the small jumper to small terminal, if the starter turns over the ground is good. Share this post Link to post Share on other sites
