ebinmaine 74,880 #2 Posted May 30, 2018 Grass..... Jungle. 2 1 Share this post Link to post Share on other sites
Sparky-(Admin) 23,892 #3 Posted May 30, 2018 Wow! That looks like it'll be a workout for your tractor! 1 Share this post Link to post Share on other sites
953 nut 62,530 #4 Posted May 30, 2018 Need to get started on the grass cutting a bit earlier in the season in the future! 3 1 Share this post Link to post Share on other sites
roadapples 6,985 #5 Posted May 30, 2018 Looks like fun but go really slow. Rocks and stumps are hard on a good deck..... Share this post Link to post Share on other sites
ebinmaine 74,880 #6 Posted May 30, 2018 3 hours ago, 953 nut said: Need to get started on the grass cutting a bit earlier in the season in the future! Oh, I don't know... Maybe they like a challenge...... 1 Share this post Link to post Share on other sites
peter lena 9,491 #7 Posted May 30, 2018 know any one with a flail mower? I would walk that entire area before cutting, for rocks or stumps, also have deck set on highest lift for most discharge, using LOW RANGE will give the deck the mechanical advantage for this job, note ease of operation with gear change. good luck , pete Share this post Link to post Share on other sites
lynnmor 8,135 #8 Posted May 30, 2018 Get a guard over that deck pulley, it can cut thru a shoe bottom in milli-seconds. Ask me how I know this. Share this post Link to post Share on other sites
Spook345 22 #9 Posted May 30, 2018 I know it's just my weird mind but it looks like it went over there to take a leak. 1 Share this post Link to post Share on other sites
Tractor boy 239 #10 Posted May 30, 2018 Jeez your tractor is trying to play Tarzan or George of the jungle. Share this post Link to post Share on other sites
Seascaper 6 #11 Posted June 2, 2018 As you can see it did a fine job, I took it slowly and carefully not taking too much at a time. Can anyone help with a wiring diagram for this model, I have the handbook and a parts diagram but could really do with the proper wire diagram. This is a new acquisition so sorting out a few matters, but cuts well, it has a 36” rear dishcharge deck. Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,775 #12 Posted June 2, 2018 Don't see a wiring diagram for any of the 5 models that show up. There should be a decal under the left side of the seat with the model number, serial number and possibly the Julian build date on it. That would help narrow it down to model year and there is possibly another model with different transmission that would lead us to a wiring diagram that could be used. Garry Share this post Link to post Share on other sites
ericj 1,579 #13 Posted June 2, 2018 did you measure the deck width, looks to me more like a 42" rear discharge deck, but I've been known to be wrong before on occasion eric j Share this post Link to post Share on other sites
Seascaper 6 #14 Posted June 5, 2018 You could be right, I will measure it when home. It is a three blade deck. Share this post Link to post Share on other sites
