Chris1055 106 #1 Posted May 29, 2018 Hi. I’ve been going through my wheel horse and was replacing the throttle cable. I loosened the brass nut so I could get the throttle cable bracket out and when I reinstalled the throttle cable and ran the tractor idles fine but if you pull the throttle out a bit it revs out of control. Unfortunately I cannot find my kohler book right now. So if you can help me get it back to about factory specs I would greatly appreciate it. Share this post Link to post Share on other sites
WHX?? 58,347 #2 Posted May 29, 2018 Section 6 Kohler K-Series SM TP-2379 LR.pdf 1 Share this post Link to post Share on other sites
Achto 32,922 #3 Posted May 29, 2018 Can you post a picture of the throttle cable set up? What size engine are you working on? Share this post Link to post Share on other sites
Chris1055 106 #4 Posted June 2, 2018 Thanks for the pdf. I didn’t turn the cross shaft all the way counter clockwise before tightening the throttle arm. thanks again Share this post Link to post Share on other sites
