mmasters 2 #1 Posted May 29, 2018 I am looking at buying a lawn ranger, can I out a cultivator on it? This looks awesome to cultivate with: 2 Share this post Link to post Share on other sites
pfrederi 20,873 #2 Posted May 29, 2018 (edited) That is not a Lawn ranger. Rangers were not designed for ground engaging implements. There is no way to raise rear mounted items. Welcome to red square!! Edited May 29, 2018 by pfrederi Share this post Link to post Share on other sites
mmasters 2 #3 Posted May 30, 2018 I am aware that wasn't a Ranger. I have read many times that the frame and rear end of a RAnger is on par with it's larger cousins. I thought a small (even home-made) cultivator could be fashioned and used to cultivate between rows. Share this post Link to post Share on other sites
pfrederi 20,873 #4 Posted May 30, 2018 The tranny is essentially the same as her bigger sisters... but there is very little ground clearance. You might be able to make something and mount it where the deck mounts. Would have to have short tines as you would have difficulty raising it high enough to clear the ground at the end of the row. Share this post Link to post Share on other sites
Dan693 510 #5 Posted June 1, 2018 As was said.....once you figure out the raising the implement part a LR can easily pull a small plow. Mine will grade up soil with no problem. Its mainly a weight thing. Mine has a 100 pound weight box and ag tires. Share this post Link to post Share on other sites
