Horse Play 393 #1 Posted May 27, 2018 My RJ58 is missing the anchor for the brake return spring. I want to make one, but haven't a clue what is looks like. Can someone post photos and some dimensions for me? Also, can anyone recommend a source for a replacement spring? Thanks for any help! Share this post Link to post Share on other sites
stevasaurus 23,652 #2 Posted May 27, 2018 Here is a picture of it just below the axle. It is 1/2" wide, 1" long and 1/4" stock and is flat.. The bolts that hold the side plates on are 1/2"...the bolt that holds on this piece is 3/4". It has a 1/4" hole for the end of the spring. They are easy to make. 5 Share this post Link to post Share on other sites
roadapples 6,987 #3 Posted May 27, 2018 Tractor Supply has a good selection of springs 2 Share this post Link to post Share on other sites
Horse Play 393 #4 Posted May 28, 2018 Thank you very much, Steve. Seems like a simple enough part. Thanks, roadapples - I'll check out TSC. 1 1 Share this post Link to post Share on other sites
Horse Play 393 #5 Posted August 23, 2018 OK, next stupid question: one end of the spring attaches to the anchor - where does the other end attach? Share this post Link to post Share on other sites
953 nut 64,661 #6 Posted August 23, 2018 13 minutes ago, Horse Play said: OK, next stupid question: one end of the spring attaches to the anchor - where does the other end attach? The brake linkage. Share this post Link to post Share on other sites
Horse Play 393 #7 Posted August 23, 2018 2 minutes ago, 953 nut said: The brake linkage. Right, but I do not see a hole anywhere to retain the spring end. Share this post Link to post Share on other sites
953 nut 64,661 #8 Posted August 23, 2018 I don't have an assembled RJ any more, but if I remember right there was a trunnion on the end of the linkage and the spring went through the eye of the cotter key that held it in place on the cross bar to the clutch. 1 Share this post Link to post Share on other sites
Horse Play 393 #9 Posted August 23, 2018 (edited) Ah, OK - makes sense. Thank you! Edited August 23, 2018 by Horse Play Share this post Link to post Share on other sites
