myron in ct 2 #1 Posted May 24, 2018 Someone posted they used a B&S fuel pump on a WH tractor . Do anyone know the B&S number ? Myron in ct. Share this post Link to post Share on other sites
wallfish 18,244 #2 Posted May 24, 2018 Low pressure electric fuel pump will work, inexpensive to $60 but it will work. Works great on my 418 with a tank below the seat. Share this post Link to post Share on other sites
953 nut 60,367 #3 Posted May 24, 2018 You can find lots of electric pumps on Ebay for under $ 10.00 that work fine. be sure to mount it low on the frame for best results. 10 hours ago, myron in ct said: B&S fuel pump on a WH tractor If a B&S pump was used it would have to be a vacuum operated pump, is that what you need? Share this post Link to post Share on other sites
