twisted metal 49 #1 Posted May 23, 2018 I need to get the steering wheel off my 754 to replace the gas tank gasket. I have had a puller on this thing since winter and from time to time spray with PB blaster and give a few taps with a hammer and it hasn't moved any. The steering wheel is in great condition so I don't want to do anything to damage it. Any ideas? Share this post Link to post Share on other sites
squonk 45,372 #2 Posted May 23, 2018 I’m assuming you took the roll pin out that holds the wheel on. You may need to use bearing separators to grab the metal part of the wheel and a big honkin puller connected to the separators 2 1 Share this post Link to post Share on other sites
ol550 844 #3 Posted May 23, 2018 If all you intend to do is replace the gasket just leave the wheel on. I have found the biggest problem is getting the base plate bolts out. 1 Share this post Link to post Share on other sites
wallfish 19,068 #4 Posted May 23, 2018 Not 100% sure of the bond they used for that steering gear at the bottom of the shaft. If it has a roll pin, knock it out and remove the gear. Most likely that steering gear is welded to the shaft, so carefully grind off the weld beads and remove that gear. Do your thing and weld the gear back on or drill a hole and use a roll pin just in case you want to do it again Without a shop press, some can be very difficult to remove from the shaft 2 Share this post Link to post Share on other sites
WHX?? 54,515 #5 Posted May 23, 2018 Rule of thumb is early 60 roll pin mid to late welded but that rule has been known to go right out the window. Can you pull the whole shaft out with tank attached and get it in an H press somehow? Not real familiar with the two piece tanks. 1 Share this post Link to post Share on other sites
953 nut 63,956 #6 Posted May 24, 2018 As Mike said, presuming the roll pin is removed you may have better luck making the steering wheel move down the shaft first. Support the fan gear support that the shaft goes to with a jack stand which will need to be supporting the weight of the tractor. Use a short pipe or other item that will fit over the 3/4" shaft and drive the steering wheel down a bit. Once it is moving a little it will be easier to pull. 5 Share this post Link to post Share on other sites
pfrederi 19,792 #7 Posted May 24, 2018 Use emory cloth to cleanup eh steering shaft below the wheel before you start. 2 Share this post Link to post Share on other sites
