Joshua Hunt 2 #1 Posted May 22, 2018 Just looking for a consensus or for anyone that has had a similar issue. Battery is approximately 8 years old. Its been a charger a lot lately and has improved a bit. Mowing last night, engine starts, drives, blades engage fine in forward (2nd) gear. Shift to reverse and everything still fine. Push clutch in and the instant the tractor is moved from reverse to 2nd gear the engine idles down (shuts off). I can instantly start it back up and continue mowing. Any thoughts? Thanks to anyone for looking. Share this post Link to post Share on other sites
WHX?? 51,455 #2 Posted May 22, 2018 What model we talkin here? I can tell you If any GT battery is 8 years old it doesn't owe anybody anything unless you got a really good one. Doesn't sound like the battery is your issue tho. 1 Share this post Link to post Share on other sites
Joshua Hunt 2 #3 Posted May 22, 2018 I am not 100% sure but will gather whatever information I can find. It is a 1970ish 8speed (Maybe 1973) I will post back this afternoon. Thanks for the reply. Share this post Link to post Share on other sites
953 nut 59,346 #4 Posted May 22, 2018 I don't think pushing the clutch in is killing the engine unless there is a frayed wire near the clutch mechanism somewhere. If properly wired the clutch safety switch is only connected to the stare wiring. Could it be that you are moving around enough that the seat switch is killing the ignition with the PTO engaged. Try doing the same thing with the PTO lever pulled back. Share this post Link to post Share on other sites
Joshua Hunt 2 #5 Posted May 22, 2018 The tractor is a C-100 8 Speed with Kohler 10hp. Share this post Link to post Share on other sites
Joshua Hunt 2 #6 Posted May 22, 2018 (edited) Clutch in, shift to reverse, then move in reverse no problem. Clutch back in, shift into 2nd and dies before clutch can even be released. Edited May 22, 2018 by Joshua Hunt Share this post Link to post Share on other sites
Ed Kennell 41,425 #7 Posted May 22, 2018 Help me understand this. With the engine running, the PTO disengaged, and the clutch pushed in. You shift in and out of reverse, first, and third and the engine keeps running. As soon as you shift into second, the engine stops Is this what I am reading? Share this post Link to post Share on other sites
953 nut 59,346 #8 Posted May 22, 2018 27 minutes ago, Joshua Hunt said: Clutch in, shift to reverse, then move in reverse no problem. Clutch back in, shift into 2nd and dies before clutch can even be released. If I an not mistaken there is a plate that the shift lever comes up through. Just a wild a$$ guess, the seat switch wires could be routed in such a manner that they are being pinched and grounded by the shift lever as you go to second gear. Pull the plate off and take a look. 4 Share this post Link to post Share on other sites
Joshua Hunt 2 #9 Posted May 22, 2018 I'm all set. Thank you everyone for your comments. Safety shut off that was bypassed connecting behind the seat was disconnected. Thanks again! 1 1 Share this post Link to post Share on other sites
