Fordiesel69 271 #1 Posted May 18, 2018 I have a thread going for clutch diagnosis. If the clutch itself is found to be bad, can a kohler magnum style manual lever clutch be installed? Reason I ask is the command pro engine looks to not have verticle load bearings just from observation. I know a harbor freight engine will fail very fast if this style of clutch is used as the crank just has plain bearings. Share this post Link to post Share on other sites
pfrederi 19,789 #2 Posted May 18, 2018 Best bet is to look up the spec# of the command pro on the Kohler website and look at the crankcase parts page. Look for a radial thrust bearing. Share this post Link to post Share on other sites
pfrederi 19,789 #3 Posted May 19, 2018 Some spec's had thrust bearings ...many did not. if it was from a WH Spec #44533 then it had a thrust bearing As an example Cub Cadet version did not.... Share this post Link to post Share on other sites
Fordiesel69 271 #4 Posted May 21, 2018 I will check the spec # on the engine. Share this post Link to post Share on other sites
