Allis37a 1 #1 Posted May 10, 2018 I have checked the coil , new plugs at .025 gap and just finished IGNITION module and plastic disk. Cranked it over with plugs out and grounded both had spark and then both lost it NO SPARK AT ALL NOW , HELP PLEASE Share this post Link to post Share on other sites
WHX?? 53,379 #2 Posted May 11, 2018 Relax Allis help is on the way. Only one who gets to shout at me is my wife! First off 2nd off did you check the coil and did you download the manuals from here? The book gives you specific trouble shooting steps as well as resistance reading of components. Check all grounds? I can only assume you meant a P220 Onan. What tractor are we working on here ....520 by any chance? Share this post Link to post Share on other sites
Allis37a 1 #3 Posted May 11, 2018 Thanks!! , yes a 520H starting to make me crazy, I did check the coil according to the manual both primary at 3.5 and secondary at 16500. Share this post Link to post Share on other sites
WHX?? 53,379 #4 Posted May 11, 2018 Check the nine pin connector, check the fuse folders.. all common 520 problems. Sometimes the fuse holders look good but are intermittent. Sounds like you have an intermittent problem. 1 Share this post Link to post Share on other sites
Allis37a 1 #5 Posted May 11, 2018 You won't believe this , I installed the plug put the battery in gave it 1 shot of starting fluid and after 3 years of setting IT LIVES!!!!!!! PURRRRRSSSSS LIKE A CAT!!!! THANKS FOR YOUR HELP!!!!!! 1 Share this post Link to post Share on other sites
