pops38 4 #1 Posted May 8, 2018 Hi all, I'm new here but have had my 417-8 for about 5 years and finally my drive belt broke. I replaced it with a supposed equivalent Kevlar belt. (82" X 5/8) which was supposed to match up with a discontinued toro108501. Anyway the belt was tight going on but I got it eventually. The new setup however only had about 2 inches of pedal movement on the clutch. Much less than before. Anyway I started it up in neutral and tried to get it in gear but there was too much gear clash almost like the clutch wasn't working. Can someone give me a little primer on how this clutch and transmission works so that I might understand what my problem is? Thanks. Share this post Link to post Share on other sites
oldlineman 1,626 #2 Posted May 8, 2018 I would say that the belt is to tight or not routed right. clutch depends on the belt getting slack enough to let it slip on the engine drive pully. Share this post Link to post Share on other sites
WHX?? 53,907 #3 Posted May 8, 2018 Pops All the belt guards & belt brakes in place and adjusted? I thought it was supposed to be an 83 incher?? Others will be along to welcome & help. Share this post Link to post Share on other sites
pfrederi 19,512 #4 Posted May 8, 2018 (edited) 108501 is for a hydro not an 8 speed 7473 is for 8 spd according to parts manual Personal preference but for gear trannies I use Toro Belts. seem to engage more smoothly.... Edited May 8, 2018 by pfrederi 2 Share this post Link to post Share on other sites
pops38 4 #5 Posted May 8, 2018 56 minutes ago, oldlineman said: I would say that the belt is to tight or not routed right. clutch depends on the belt getting slack enough to let it slip on the engine drive pully. Nah, It's routed right, but I can tell that it's too tight for the belt to slip on the engine pulley. So that's how the clutch works, by slipping. Well I'll be doggone. Never paid much attention to the transmission and clutch until this happened. Thanks for the reply. Share this post Link to post Share on other sites
pops38 4 #6 Posted May 8, 2018 40 minutes ago, pfrederi said: 108501 is for a hydro not an 8 speed 7473 is for 8 spd according to parts manual Personal preference but for gear trannies I use Toro Belts. seem to engage more smoothly.... You're right! My bad. I meant the 7473. I read the wrong number off of my research notes. So this belt, I ordered, was claimed to be a replacement for the 7473. I guess not, at least in this case. I'll go to our toro dealer and get one. Thanks for the input! 1 Share this post Link to post Share on other sites
WHX?? 53,907 #7 Posted May 9, 2018 Your welcome Pops ....When lookng for a "correct" size belt I get one either size of what I believe to be correct. Take what doesn't work back.Works for me real well. I get them at a local TSC. 1 Share this post Link to post Share on other sites
Ed Kennell 44,134 #8 Posted May 9, 2018 (edited) Just a reminder....The belt guard must be in place for the clutch to work properly. The bottom flange on the belt guard provides the support for the declutched slack belt preventing it from drooping and contacting the drive pulley. Edited May 9, 2018 by Ed Kennell 1 Share this post Link to post Share on other sites
Tuneup 1,452 #9 Posted May 9, 2018 What about the clutch adjustment? If the old belt was slacking and he adjusted it tighter, wouldn't you now want to loosen it back to the 'new belt' position? Just tossing this out there but any adjustment is worth a look-see. Share this post Link to post Share on other sites
pops38 4 #10 Posted May 9, 2018 (edited) 17 minutes ago, Tuneup said: What about the clutch adjustment? If the old belt was slacking and he adjusted it tighter, wouldn't you now want to loosen it back to the 'new belt' position? Just tossing this out there but any adjustment is worth a look-see. This is one thing that I was wondering. How is this adjustment made? I could not find any info online or in my owners manual. I would be very curious to see if there is an adjustment to be made. Like I said, I had a heck of a time getting the new belt on. I was looking for an adjustment at the time so to get the belt on I loosened the idler pulley enough to get some extra slack. Edited May 9, 2018 by pops38 more information Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,932 #11 Posted May 9, 2018 There is no adjustment for belt length. You can adjust the rod from the pedal on the left side to accommodate operators with different leg lengths. Just changes the pedal position when it is in the rest position. Could you have installed the belt if the pedal had been held down? That is a worthless question in a way because the idler would still have to be loosened to get the belt between the L-bracket and the idler groove. Garry Share this post Link to post Share on other sites
pops38 4 #12 Posted May 9, 2018 To wrap this up. I went and got an OEM Toro belt 7473 same number as the aftermarket 7473 except it was probably 1/2" to 3/4" longer when held up to the aftermarket belt. I was a little skeptical. Installed the OEM belt and immediately saw I had more clutch pedal travel than the aftermarket belt, Put machine back together and the new belt worked perfectly. Thanks for the guidance to buy OEM. This is apparently critical for this application. Too bad the aftermarket belt got a little dinged up. Can't really return it. It probably works in lots of applications because I saw it got about 4.5 out of 5 stars from most buyers. Thanks to all who chimed in. 1 2 Share this post Link to post Share on other sites
Tuneup 1,452 #13 Posted May 9, 2018 4 to 5 stars for them there MTD tractors So glad you got it done! Enjoy the tractor. Share this post Link to post Share on other sites
doc724 925 #14 Posted May 18, 2018 If you read the forums regularly, there are many people here who recommend that you only buy Toro belts for drive belt applications. They claim that there are dimensional differences between Toro and aftermarket belts. I cannot confirm if that is true or not but I have only bought Toro belts and never had a problem. Plus, Toro belts are often less costly that Stens or other aftermarket belts. I always avoid buying low cost belts as well. I am a firm believer in you get what you pay for and when a drive belt snaps, it is not a 5 minute task to reinstall a new one-especially if it happens in the field. Share this post Link to post Share on other sites
WHX?? 53,907 #15 Posted May 18, 2018 I gotta tell ya guys I just searched ebayed a 114895 5/8 x 83" belt for a 520 and found this. Ordered one figuring it would be a cheap schooling if nothing else. Quite impressed with it so far tho. Was made of rubber much like OEM Toro Belts, not Kevlar wrapped and rode a bit high on the pulleys for hopefully good wear in to the pulleys. Don't know if is same dimensionally as OEM but for 15 clams don't care. Time will tell. https://www.ebay.com/itm/REPLACEMENT-BELT-FOR-Toro-107939-108502-112801-114895-8160-93-9809-5-8-x83/190942297055?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2057872.m2749.l2649 Share this post Link to post Share on other sites
