Spareparts 86 #26 Posted May 12, 2018 Check end play on the crankshaft, if the thrust bearing is going out you might excessive end play 2 Share this post Link to post Share on other sites
CW418A 5 #27 Posted September 7, 2018 Well it was the thrust bearing and we did have about a 1/4 play on the crankshaft. They recommended a rebuild or a new engine. Just went and found a low hour 416H and a 312H and spent less on both than to replace the motor. 1 1 Share this post Link to post Share on other sites
Spareparts 86 #28 Posted September 20, 2018 Don't discard the camshaft, the pullers with the K-341's like that shaft, a little more lift than the stock 341's. Check Brian Millers web site, might be worth a little change. Share this post Link to post Share on other sites
CW418A 5 #29 Posted September 20, 2018 13 hours ago, Spareparts said: Don't discard the camshaft, the pullers with the K-341's like that shaft, a little more lift than the stock 341's. Check Brian Millers web site, might be worth a little change. I found two much newer wheel horse tractors for $900 on with 300 hours and one with 500. For that it doesnt pay to put money into a 1800 hour tractor. Share this post Link to post Share on other sites
