clueless 3,437 #1 Posted May 7, 2018 As the ladies say, I'm a plus size guy, 300# before hibernation, 285 coming out of hibernation. The seat springs on my round hoods look to be at their limit, and any semi rough terrain is hard on them and me. Any suggestions for adding extra support. Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,483 #2 Posted May 7, 2018 Single flat spring about 3" wide? The old walking Gravely sulkies used about 1-1/2 springs doubled up. The 2nd spring goes about 1/2 way up to the seat. Garry This one is shorter than mine but you get the idea. 1 Share this post Link to post Share on other sites
Achto 32,622 #3 Posted May 7, 2018 Maybe stuff a coil spring inside of the original spring. Share this post Link to post Share on other sites
wallfish 20,576 #4 Posted May 7, 2018 (edited) Adding more tension will probably make a more rougher ride. How about using spacers under the spring at the trans to raise it up? Low tire pressure will absorb some of shock too. And a seat cushion. Just though of a solution! Air bag for air ride system Edited May 7, 2018 by wallfish 2 Share this post Link to post Share on other sites
