Keith 21 #1 Posted May 1, 2018 I got a Chinese carb for my K341 and the air cleaner screws won't fit. I suppose I can re-tap the holes. Share this post Link to post Share on other sites
ebinmaine 76,990 #2 Posted May 1, 2018 They're likely tapped metric. You could bring the carb to the hardware store and get some correct fasteners. 2 Share this post Link to post Share on other sites
rmaynard 16,836 #3 Posted May 1, 2018 Good lesson for anyone considering the purchase is a Chinese carburetor. Always look for one that advertises SAE (American) threads and correct choke. Not only are the screws metric on most imports, but so is the inlet for the fuel. Many have the choke lever backwards as well. 3 Share this post Link to post Share on other sites
pfrederi 19,727 #4 Posted May 1, 2018 Just went through this They are M4 x 8mm. Just got a box. You want 3 I can mail them to you. 1 Share this post Link to post Share on other sites
WHX?? 54,329 #5 Posted May 1, 2018 5 hours ago, rmaynard said: but so is the inlet for the fuel. Just put one on a K91 and it used Paul's 4 mm screws but oddly enough it was !/8" npt for the fuel inlet. It runs the motor great tho. Share this post Link to post Share on other sites
Keith 21 #6 Posted May 2, 2018 12 hours ago, pfrederi said: Just went through this They are M4 x 8mm. Just got a box. You want 3 I can mail them to you. I got some M4-8 screws and they are too small. Share this post Link to post Share on other sites
WHX?? 54,329 #7 Posted May 2, 2018 (edited) Might be 6's on the bigger carbs.... On 5/1/2018 at 3:22 AM, ebinmaine said: could bring the carb to the hardware store Unless you are like me and mounted & plumbed the carb already! Try standard threads as Bob said some may be standard. Don't forget backing & lock washers don't want one of those screws coming loose and (try to) go thru the motor! Edited May 2, 2018 by WHX17 Share this post Link to post Share on other sites
Keith 21 #8 Posted May 4, 2018 The screws were 5mm, all I found were too long so I will grind them down to fit. 2 Share this post Link to post Share on other sites
