murph 5 #1 Posted April 27, 2018 Hi,I been told by a repair shop that i need to bore .010 over and get a new piston,but they seem to be having trouble locating one.I told them I really want OME parts any one know of a good source,I think he used the type of piston he was looking for was "molly or mule not sure of that name but it is a 1993 mag 14,thanks for the help, \ Share this post Link to post Share on other sites
953 nut 63,941 #2 Posted April 27, 2018 35 minutes ago, murph said: think he used the type of piston he was looking for was "molly or mule not sure of that name You can find them, but when you see the price you may change your mind. Brian Miller would be the best place to try. http://gardentractorpullingtips.com/a1miller.htm#rebuildparts Kohler K-series and Magnum models K321, M14 and K582 Ring Sets, and Piston and Ring Sets (includes wrist pin and retaining clips). (The K321, M14 and K582 engines use the same piston and rings.) Priced per cylinder. Compression height is 1.7". Rings made of high grade cast iron for durability. And being the wrist pin is centered, these pistons can be installed in either direction. IMPORTANT: Click here for proper break-in (wear-in) oils and procedure for rebuilt engines. STD Size Ring Sets Only (3.500" cylinder bore size.). Fits K-series cast piston. Aftermarket. Same quality as OEM Kohler. $24.00 each, plus shipping & handling. Fits K-series cast piston. OEM Kohler part # 48 108 05-S. $101.23 each, plus shipping & handling. Fits Mahle piston. OEM Kohler part # 47 108 05-S. Discontinued from Kohler. L STD Size Pistons and Ring Sets (3.500" cylinder bore size.). Cast piston and rings. Aftermarket. Same quality as OEM Kohler. $55.00 each, plus shipping & handling. Cast piston and rings. OEM Kohler part # 47 874 11-S. Discontinued from Kohler. L Mahle piston and rings. OEM Kohler part # 47 874 21-S. Discontinued from Kohler. L .003" Oversize Cast Piston and Ring Set (3.503" cylinder bore size.). OEM Kohler part # 47 874 12-S. $191.75 each, plus shipping & handling. .010" Oversize Ring Sets Only (3.510" cylinder bore size.). Fits K-series cast piston. Aftermarket. Same quality as OEM Kohler. $12.00 each, plus shipping & handling. Fits K-series cast piston. OEM Kohler part # 48 108 06-S. $92.76 each, plus shipping & handling. Fits Mahle piston. OEM Kohler part # 47 108 06-S. Discontinued from Kohler. L .010" Oversize Pistons and Ring Sets (3.510" cylinder bore size.). Cast piston and rings. Aftermarket. Same quality as OEM Kohler. $52.00 each, plus shipping & handling. Cast piston and rings. OEM Kohler part # 47 874 13-S. $247.81 each, plus shipping & handling. Mahle piston and rings. OEM Kohler part # 47 874 23-S. $301.81 each, plus shipping & handling. .020" Oversize Ring Sets Only (3.520" cylinder bore size.). Fits K-series cast piston. Aftermarket. Same quality as OEM Kohler. $15.00 each, plus shipping & handling. Fits K-series cast piston. OEM Kohler part # 48 108 07-S. $119.30 each, plus shipping & handling. Fits Mahle piston. OEM Kohler part # 47 108 07-S. $106.22 each, plus shipping & handling. .020" Oversize Pistons and Ring Sets (3.520" cylinder bore size.). Cast piston and rings. Aftermarket. Same quality as OEM Kohler. $49.00 each, plus shipping & handling. Cast piston and rings. OEM Kohler part # 47 874 14-S. Discontinued from Kohler. L Mahle piston and rings. OEM Kohler part # 47 874 24-S. Discontinued from Kohler. L .030" Oversize Ring Sets Only (3.530" cylinder bore size.). Fits K-series cast piston. Aftermarket. Same quality as OEM Kohler. $14.50 each, plus shipping & handling. Fits K-series cast piston. OEM Kohler part # 48 108 08-S. $119.30 each, plus shipping & handling. Fits Mahle piston. OEM Kohler part # 47 108 08-S. Discontinued from Kohler. L .030" Oversize Pistons and Ring Sets (3.530" cylinder bore size.). Cast piston and rings - high quality aftermarket. $49.00 each, plus shipping & handling. Cast piston and rings. OEM Kohler part # 47 874 15-S. $247.81 each, plus shipping & handling. Mahle piston and rings. OEM Kohler part # 47 874 25-S. Discontinued from Kohler. L .040" Oversize Pistons with Rings (3.415" cylinder bore size.). Ring set not available separately. L Cast piston and rings. Aftermarket. Same quality as OEM Kohler. OEM Kohler-replicated; fits K321, M14 and K582 engines. Irrelevant Kohler part number. $60.00 each, plus shipping & handling. 1 Share this post Link to post Share on other sites
MalMac 1,334 #3 Posted April 27, 2018 I sent you a PM Share this post Link to post Share on other sites
