carlosking450 161 #1 Posted April 25, 2018 Hello everyone, greetings from Spain after I restored my 702 and put it into operation I realized that the starter motor rotates without force, even sometimes I must help you with your hand because in some places it remains stuck, the battery is new and the motor turns freely, do you know what the problem may be? thanks Share this post Link to post Share on other sites
pfrederi 19,810 #2 Posted April 25, 2018 (edited) Is the belt slipping on either engine or starter/Generator pulley? Does it charge the battery when it is running? (Do you have about 14 volts DC when running?) if the belt isn't slipping and the Generator charges when running could be a field coil in the starter/generator is failing or failed. I would take it to an automotive starter/generator repair place .. They can test it and probably get parts to fix it. Edited April 25, 2018 by pfrederi 3 Share this post Link to post Share on other sites
carlosking450 161 #3 Posted April 25, 2018 The belt does not slip, and the load does not check it because I do not know where to measure the current Share this post Link to post Share on other sites
pfrederi 19,810 #4 Posted April 25, 2018 (edited) Put your volt meter (multimeter) on the + and - battery terminals. Should get 12.6 volts engine off. With engine running about 14 volts Coloque su voltímetro (multímetro) en los terminales + y - de la batería. Debería desconectar el motor de 12.6 voltios. Con el motor funcionando a unos 14 voltios Edited April 25, 2018 by pfrederi Share this post Link to post Share on other sites
carlosking450 161 #5 Posted April 25, 2018 The belt does not slip, and the load does not check it because I do not know where to measure the current Share this post Link to post Share on other sites
pfrederi 19,810 #6 Posted April 25, 2018 3 minutes ago, carlosking450 said: The belt does not slip, and the load does not check it because I do not know where to measure the current Measure voltage at the battery engine off and then again running. Share this post Link to post Share on other sites
