ronhatch 410 #1 Posted April 24, 2018 What is the preferred type of bearing for a mower deck; sealed or shield? Share this post Link to post Share on other sites
Cvans 1,009 #2 Posted April 24, 2018 (edited) If it's a greasable spindle I will use sealed bearings and remove the inside seal on each bearing. If it's not greasable then use sealed bearings. There is too much chance of getting dirt and water in them to use shielded bearings. Edited April 24, 2018 by Cvans 3 Share this post Link to post Share on other sites
WHX?? 58,306 #3 Posted April 24, 2018 I don't think it matters a great deal Ron both types are made to wear out. . I run sealed just to help keep water out but wash my decks a lot. Sealed ones are also easier to pick the inside seal out for those who like to grease. 3 Share this post Link to post Share on other sites
pacer 3,180 #4 Posted April 24, 2018 After running a Yard Man tractor for several years using sealed bearings in a similar spindle setup and having the bearings last and last, I have started using them on my horses. Got one thats in its 3rd season and still OK. I always hated having to pump and pump grease into the spindles to get the little bit of grease actually needed. Along this same vein, I have also changed the front wheel spindles to sealed bearings also. 3 1 Share this post Link to post Share on other sites
Cvans 1,009 #5 Posted April 25, 2018 Just a thought here, on sealed bearings (especially Chinese) I fill a syringe with grease and add extra grease to the bearing before installing it. Just slip the needle under the lip of the seal and add a little. Don't over do it or the bearing will heat up. I have also re-greased them this way. Share this post Link to post Share on other sites
peter lena 10,090 #6 Posted April 25, 2018 found ( royal purple ) grease to be the saver in spindle bearings and the pto needle bearing , not only is it an ultra performance rating grease , but you will notice and feel a smoother and faster running pto driven system. my mower decks and snow blower run without effort and drag. also take the time to lubricate and ( snug up ) any of the mechanical lever /engagement points, so the engagement is effortless. pete Share this post Link to post Share on other sites
ronhatch 410 #7 Posted April 25, 2018 Just to be clear, I was referring to the type of bearing seal that is best for a none greasable spindle, a black plastic seal or the metal shield, which I guess is also considered a seal.. Thanks Share this post Link to post Share on other sites
1995 520H+96+97 939 #8 Posted April 25, 2018 Shielded would likely keep dirt and grass out of the lower spindle bearing. 1 Share this post Link to post Share on other sites
doc724 927 #9 Posted April 25, 2018 On every deck spindle and tractor front wheels that I rebuild, I use double sealed bearings (double seal means a seal on both sides) and I remove the zerk fitting and replace it with a set screw so no one can screw it up. Why? Because if you let someone pump grease thru a zerk, you can never control that they will only put in three pumps worth. People will pump until the grease comes out somewhere and that means that you have popped the single seal on one or more bearings, not to mention the mess and the anger from the Mrs. if you happen to track some of that spilled grease into the house. Now the seal is good for nothing but to let water IN. Also, I use only high quality bearings, Heim or equal. None of these $5 Chinese bearings for me. 1 1 Share this post Link to post Share on other sites
Cvans 1,009 #10 Posted April 26, 2018 11 hours ago, ronhatch said: Just to be clear, I was referring to the type of bearing seal that is best for a none greasable spindle, a black plastic seal or the metal shield, which I guess is also considered a seal.. Thanks Sealed. Share this post Link to post Share on other sites
