SgtBob 27 #1 Posted April 23, 2018 Just wondering if the Onan in the 416 has the same valve seat issues as the 520. I have heard a lot about the 520's but not the 16HP Onan. I would believe they are the same but would like someone with more knowledge to chime in. Thank you for any insight you can provide. Share this post Link to post Share on other sites
littleredrider 409 #2 Posted April 23, 2018 I would think so since it’s the same setup...but maybe they don’t produce the heat a 20horse does? Share this post Link to post Share on other sites
BESTDOGEVER 218 #3 Posted April 23, 2018 I am pretty sure that they are the same. The problem is that the air flow is bad on that cylinder leading to the failure . There are many posts here about ventilating that belt guard that will help a lot Share this post Link to post Share on other sites
SgtBob 27 #4 Posted April 23, 2018 Thank you for your time. That's what I was thinking but wanted another opinion. Share this post Link to post Share on other sites
Pollack Pete 2,273 #5 Posted April 23, 2018 Gotta keep oil leaks around the oil filter at bay.The dirt and grass clippings stick to motor oil like a magnet.Also a good compressed air blast behind the cooling tins after every mow will help keep the crap out of those rear cylinder cooling fins.I've only used a 520H for snow blower duty.Never had any worries about over-heating that big Onan. 1 Share this post Link to post Share on other sites
