Lambeater 14 #1 Posted April 23, 2018 Good morning guys, finally got the H60 on my lawn ranger running but it will only run at higher revs and no idle. So tore some of it apart but still the same, Fitted new plug, cleaned and set points, new condenser, timing set at .080 ( i found TDC and then turned counter clockwise to 080 on my dial. which is almost around again). Complete new fuel system and new carb (chinese). Not sure how the governor works though. Carb seems adjusted correctly. Any help would be much appreciated. thx Lambeater Share this post Link to post Share on other sites
953 nut 63,919 #2 Posted April 23, 2018 This manual should give you the right info.. Share this post Link to post Share on other sites
Lambeater 14 #3 Posted April 24, 2018 thankyou much appreciated, Lambeater Share this post Link to post Share on other sites
