paleoman 0 #1 Posted April 20, 2018 I'm kinda in a jam, Kohler manual shows that a K301 has an oil cap. of 2 qts. But my dip stick has always shown full at 1-1/2 qts. Just did a rebuild after 9 years and put in the full 2 qts. ran beautiful... for a while... then just quits. hard to start.. blows smoke, back fires and then sometimes it will run very smooth for about 10 sec and quits again. same story repeats... so, over filling oil can cause weird issues like this? THX folks! Mark Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,975 #2 Posted April 20, 2018 Wheel Horse did publish lubrication charts. What to use and how much. Garry 1 Share this post Link to post Share on other sites
pfrederi 19,783 #3 Posted April 20, 2018 What color smoke??? What model tractor...Isolation mounts had smaller than normal oil pans and less capacity Share this post Link to post Share on other sites
oldlineman 1,628 #4 Posted April 20, 2018 my 1979 c-101 with shaker mount holds 1 and 1/2 qt. I just changed it if that helps. 1 Share this post Link to post Share on other sites
rmaynard 16,837 #5 Posted April 20, 2018 The C-101 has a K-241AS and uses 1-1/2 qts. Your engine probably has an embossed number "K-301" on it because both engines use the same block. The "AS" designation means the oil pan was designed to fit into the shaker cradle, and it's a bit smaller than a normal K-241 or K-301 with the large pan. 2 Share this post Link to post Share on other sites
Racinbob 12,648 #6 Posted April 20, 2018 Bingo. The shaker mounts call for 1 1/2 quarts. 2 Share this post Link to post Share on other sites
953 nut 63,916 #7 Posted April 20, 2018 1 hour ago, paleoman said: ran beautiful... for a while... then just quits. hard to start.. blows smoke, back fires and then sometimes it will run very smooth for about 10 sec and quits again. same story repeats. The symptoms you have listed are consistent with low carburetor float adjustment or ignition points out of adjustment. I would begin by doing a static timing which is the most accurate way to set points gap. Kohler static_timing.pdf 3 Share this post Link to post Share on other sites
clueless 3,347 #8 Posted April 21, 2018 All the above. Share this post Link to post Share on other sites
paleoman 0 #9 Posted April 28, 2018 Thanks everyone for your help! The issue was certainly oil level. The plug oil fowled. 1-1/2 Qts is correct. Thanks again everyone for your help! God bless! Share this post Link to post Share on other sites
tunahead72 2,600 #10 Posted May 1, 2018 @paleoman Just for clarity, what tractor was this for? Share this post Link to post Share on other sites
