Similar Content
By Fordiesel69
Need a pair or rear rims for 518xi, 520Lxi, 522xi, 523dxi, GT18, GT20, GT22, GTD23D, tractors. Can take new old stock, nice used, or used that need refurbishing. Anything will be fine. Needs to be within 2 hrs of Erie, PA, or shipping available.
Thank you,
Mike.
By MachXXII
I’m trying to restore my grandfathers old 252-H to use around my property. The tires are shot and the rims aren’t too far behind. Anyone have any recommendations for rims and tires that would fit well on it?
right now it has 22 x 7.50 - 12 on the back and 15 x 6 - 6 on the front.
By Noremakcw
Trying to design and 3D print the front emblem. Below is my model. Any body who want to try out 3D modeling and 3D printing, I’m using Onshape (this file is public so you should be able to find it) and an ender 3 v2 printer.
By r1jakecfd
Hi Guys,
I just bought some Carlisle Turfmaster 24x12-12 rear tires to replace the 23x8.50-12 tires I have on there now. I was wondering which rims I should buy to fit these bigger tires. The charts say an 8.50 width rim but should the offset stay the same or does it need to change? Any other dimensions I should be concerned about?
Thanks in advance.
Hope everyone is healthy and well!
John
By Spini
I'm thinking about going with 7.50 tires on the front with the 8" stock rims. I mow in a wet area and am thinking if I increase the surface area, I'll be less likely to sink. I already went wider in the rear, which seems to work well. I'm also running lower pressures all around.
My main concern is if the slightly wider tires will clear the mower deck when I make tight turns. As it is, the 6.50 clears only by about an inch.
I'd like to go with the 7.50 Carlisle Turf Masters, the mounted width is 7". Currently I am running the stock tires, which are Turf Savers, and according to Carlisle, the mounted width is 6.6".
I guess if that's the case, it may not make much difference in surface area, and I would be risking rubbing the tires on the deck. I have a 42" deck.
If anyone is using (or knows for sure if) 7.50 Turf Masters on an 8" wheel with a 42" deck on a 416-8, please let me know how well it works. Obviously
I can't risk "tire rub".
I also welcome any other suggestions for mowing wet ground. Thanks in advance.
