"Manic-Mechanic" 1,420 #1 Posted April 14, 2018 (edited) I needed to build a Power Washer as the one we had a very selfish person dismantled! I managed to at least retrieve the engine! Picked up this excellent Honda Chassis & Greencan Pump from CA. 2700 PSI. I didn't want to exceed the limit on the Subaru Robin EX13 (5 hp engine), so this should work wonderfully. I will be testing everything here soon. This is the engine I had to really tear into the carb and replace some governor springs, minor adjustments and it runs smooth. However, already not liking the Greencan Pump as it has a wee dip stick to maintain oil level, very difficult to get fluids between the high & low! Edited April 14, 2018 by Oldman 2 Share this post Link to post Share on other sites
ebinmaine 76,033 #2 Posted April 14, 2018 I'll be following along to watch the progress. 1 Share this post Link to post Share on other sites
"Manic-Mechanic" 1,420 #3 Posted April 14, 2018 (edited) Gotta love o'l Orchid Beach! Here is some progress, all the assembly is done final part installed, the M22 fitting. Notice the wee dip stick, ridiculous to get between the high & low! I need a nice day to test run the unit. "Looks good". Edited April 16, 2018 by Oldman Additiion 1 Share this post Link to post Share on other sites
"Manic-Mechanic" 1,420 #4 Posted April 18, 2018 Ok, well the pump seems to do it's job and good pressure, however, the engine seriously just bogs down drastically, almost like the governor isn't performing or the pump is too much for the engine? Very sad to see this. Also the oil level in the pump seemed to climb after a bit? The water coming out had white foam all through it at first, maybe rinsing factory chemicals out of the unit? Any thoughts greatly appreicated. Oldman Share this post Link to post Share on other sites
"Manic-Mechanic" 1,420 #5 Posted April 19, 2018 The pump needed adjusted accordingly, it's probably closer to 2600psi now and it works great! I had to ask questions Green Canpump.com of Toronto was extremely helpful with this respect. Glad I don't need another engine or anything drastic like that! I have zero knowledge of power washers as I usually just did things the old way, bucket and brush! Lol Oldman. Share this post Link to post Share on other sites
