DANIEL/ALEASHA 2 #1 Posted April 12, 2018 We have a 1968 Wheel Horse with the automatic drive where it has a hydraulic pump does anyone know About if it has gear oil and hydraulic fluid and what types do I use Share this post Link to post Share on other sites
953 nut 64,275 #2 Posted April 12, 2018 They are a one piece unit and use Dextron ATF unless it has been changed out. Check the dip stick and look at the color. If it is pink or red it is ATF, if amber it is 10 W 30. Sundstrand Transmission Wheel-a-Matic 1969 (1).pdf 3 1 Share this post Link to post Share on other sites
DANIEL/ALEASHA 2 #3 Posted April 12, 2018 49 minutes ago, 953 nut said: They are a one piece unit and use Dextron ATF unless it has been changed out. Check the dip stick and look at the color. If it is pink or red it is ATF, if amber it is 10 W 30. Sundstrand Transmission Wheel-a-Matic 1969 (1).pdf Share this post Link to post Share on other sites
DANIEL/ALEASHA 2 #4 Posted April 12, 2018 That is very helpful thanks a lot 2 Share this post Link to post Share on other sites
DANIEL/ALEASHA 2 #5 Posted April 12, 2018 I got a Wheel Horse Raider 10 do you got the manual for that style of 6 speed it's the one that has three forward reverse and high and low gear on another shifter or you can say low and high range with three forward and reverse Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,014 #6 Posted April 12, 2018 Do you know what the model number of the transmission is? If not post the model number of the Raider. ID plate may be up high below the dash panel. Here is the service manual. Click on the picture If the file is too large for you try this one Garry 1 1 Share this post Link to post Share on other sites
DANIEL/ALEASHA 2 #7 Posted April 12, 2018 Thank you i think thats it You don't happen to know where to get a rebuild kit for that Raider tens fuel pump it's got a Tecumseh hh100 on it Share this post Link to post Share on other sites
