Mjh 33 #1 Posted March 24, 2018 Ok I had a previous post about my 520H cutting out. Was out cleaning up yard getting ready for spring mowing. Decided to make a pass with pto engaged. Never made complete pass when it cut off. So I engaged and disingaged pto a few times. And it started back up. I'm nearly certain switch is bad? I'm the only operator of this tractor. So want to bypass pto switch. Mine has 2 plugs on switch 1995. Any how to information would be great. I'm going out now to pull battery and see if I can figure it out. Just thought if someone had already done this your input would be appreciated. Thanks in advance!!!! Have a great day🇺🇸 Share this post Link to post Share on other sites
953 nut 63,075 #2 Posted March 24, 2018 Pull the wires one at a time, clean and tighten each connection. Two of them go to the ignition via the seat switch and two are in the start wiring to prevent starting with PTO in gear. 1 Share this post Link to post Share on other sites
