R. L. Addison 300 #1 Posted March 23, 2018 (edited) Went with a friend to pick up a B-12 A.C. today, and wound up with the B-12 and a charger 10 & short wheel-base snow blade. Don't know yet what I have yet, the blade is short all the angling parts, lever, push/pull angling rod, all the pin pull parts, so basically all i got was the backboard,springs angular segment & short wheel base frame. Tractor has been jua-kalied til it is almost not recognizable in places (especially electrically) mechanically I have to check out yet. Got to soak it down and free up steering, drawbar pin, & more then the fun starts trying to get the Tecumseh engine running, & then go to hydrostat, Been sitting a long time in the weather. Ron A. Edited March 23, 2018 by R. L. Addison Interruption 1 Share this post Link to post Share on other sites
953 nut 66,628 #2 Posted March 23, 2018 28 minutes ago, R. L. Addison said: almost not recognizable in places (especially electrically) mechanically I have to check out Fortunately they are simple straight forward tractors. Good luck. Share this post Link to post Share on other sites
R. L. Addison 300 #4 Posted March 24, 2018 Can't do pictures yet, still have not been able to pay my support yet. Think i'm going to let a bill or two go to pay shortly.. That Tecumseh is mag run & ground to kill, am I right? Ron A. Share this post Link to post Share on other sites
Ed Kennell 46,225 #5 Posted March 24, 2018 file:///C:/Users/asus/AppData/Local/Microsoft/Windows/INetCache/IE/JHOZ30UX/Tractor 1969 Charger 10 1-7041 OM IPL Wiring 1-7041-P.pdf Raider was 8 speed gear drive. Charger was hydrostatic drive. Yes, the HH100 Tecumseh would be Magneto ignition. 2 Share this post Link to post Share on other sites
pfrederi 20,675 #6 Posted March 24, 2018 9 hours ago, Ed Kennell said: file:///C:/Users/asus/AppData/Local/Microsoft/Windows/INetCache/IE/JHOZ30UX/Tractor 1969 Charger 10 1-7041 OM IPL Wiring 1-7041-P.pdf Raider was 8 speed gear drive. Charger was hydrostatic drive. Yes, the HH100 Tecumseh would be Magneto ignition. It functions like a mag but it is actually a Solid State ignition system. Like the Kohler breakerless ignition the techy module is NLA and used ones that work come dear...so make absolutely sure you do not fry it by applying voltage to the kill wire. 1 Share this post Link to post Share on other sites
squonk 46,876 #7 Posted March 24, 2018 Get the Tecky running first. It's all down hill from there! 1 Share this post Link to post Share on other sites
