scott willey 34 #51 Posted March 25, 2018 still available from toro $44.00 each Share this post Link to post Share on other sites
pfrederi 17,168 #52 Posted March 25, 2018 (edited) You can get US made Heim bearings (same brand as WH used years ago) $8.37 Edited March 25, 2018 by pfrederi 1 Share this post Link to post Share on other sites
ronhatch 405 #53 Posted March 25, 2018 11 hours ago, wallfish said: Believe he's referring to these type. They're not tapered but roller bearings for the 3/4 spindle straight shaft x 1 3/8 OD I wouldn't be comfortable using those roller bearings because they use the unhardened spindle as an inner race. I'll stick with a good quality sealed ball bearing. And just to beat a dead horse a little more ;-), I'll ask the question; Wouldn't a external snap ring be better then a "C" clip to hold the front wheel on? I think so. 1 Share this post Link to post Share on other sites
tarcoleo 119 #54 Posted March 25, 2018 (edited) Edited March 25, 2018 by tarcoleo 1 1 Share this post Link to post Share on other sites
tarcoleo 119 #55 Posted March 25, 2018 Previous post refers to discussion about these roller bearings. Click away 1 1 Share this post Link to post Share on other sites
ronhatch 405 #56 Posted March 25, 2018 (edited) I agree. Cleaning and re-greasing on a regular PM schedule would be necessary with the roller bearings. Seals to keep the dirt out would be a big help too. The best would be to exchange the rims with ones off a tractor (or whatever) that uses tapered roller bearing like my round fender JD or my B-10 AC has. I don't understand why my 4016 Case/Ingersoll only has ball bearings! FYI; Ford always used Timken tapered roller bearings in their front wheels, even in their Model A's (Model t's?), while Chevy used cheap Bendex ball bearings all the way up to 1962. Chevy owners, in those days, needed to make sure their front wheel bearings were serviced regularly. I learned the hard way, but I was just a kid. Edited March 25, 2018 by ronhatch 1 Share this post Link to post Share on other sites
WVHillbilly520H 10,369 #57 Posted March 25, 2018 3 minutes ago, ronhatch said: I agree. Cleaning and re-greasing on a regular PM schedule would be necessary with the roller bearings. Seals to keep the dirt out would be a big help too. The best would be to exchange the rims with ones off a tractor (or whatever) that uses tapered roller bearing like my round fender JD or my B-10 AC has. FYI; Ford always used Timken tapered roller bearings in their front wheels, even in their Model A's (Model t's?), while Chevy used cheap Bendex ball bearings all the way up to 1962. Chevy owners, in those days, needed to make sure they're front wheels bearing were serviced regular. I learned the hard way, but II was just a kid. The 520H front wheels use the tapered roller bearings plus have a grease zerk for periodically regreasing as well as the rear dust/grease seal and front hub covers, Jeff. 1 1 Share this post Link to post Share on other sites
