Red144runner 658 #1 Posted March 18, 2018 I have all the parts to do the swap. Do I need to change the steering wheel shaft as well or can I keep the 3-12 shaft and run 520 parts from the reduction forward? Share this post Link to post Share on other sites
cleat 8,378 #2 Posted March 18, 2018 You need the shaft as well. The bottom end and gear are different. Length will likely be a bit different as well so your steering wheel may sit up just a little higher. 4 Share this post Link to post Share on other sites
