mikeeyre74 290 #1 Posted March 16, 2018 My 520 isn’t charging. I have 12.6 V at the battery, and I have checked all the fuses and cleaned terminals. I suspect it is the voltage regulator. I’m getting 2.9 V at the B plus terminal at idle, and up to about 7 V at full throttle. My question is, when the engine is off with the key switch on, shouldn’t I get battery voltage to the B+ terminal? Right now, I get nothing until it’s running. Share this post Link to post Share on other sites
cleat 8,723 #2 Posted March 16, 2018 Yep, check all connections. That is precisely the reason to go straight from the regulator to the battery cable at the starter solenoid with a 30A inline fuse. 9 pin can't handle that kind of current. Also check the 30A fuse. Cleat 1 Share this post Link to post Share on other sites
mikeeyre74 290 #3 Posted March 16, 2018 The 9 pin was removed by the PO and it was all shucked in favor of bullet connectors and shrink wrap. I've got batt voltage at the fuse on both sides..so that should be good? Share this post Link to post Share on other sites
Ed Kennell 44,723 #4 Posted March 16, 2018 (edited) The VR must be grounded. Loosen and retighten the VR mounting bolt Replace the VR...$20 on line. Edited March 16, 2018 by Ed Kennell Share this post Link to post Share on other sites
953 nut 63,986 #5 Posted March 16, 2018 9 hours ago, mikeeyre74 said: when the engine is off with the key switch on, shouldn’t I get battery voltage to the B+ terminal? Right now, I get nothing until it’s running. Clean and tighten the voltage regulator mounting point and all other connections including grounds. The voltage at the B+ terminal with the engine off and key on should be full battery voltage, if it is not there are bad connections in the system. The two wires coming from the engine should show 36 volts AC between them with the engine running at near WOT. Share this post Link to post Share on other sites
