classicdmax 190 #1 Posted March 15, 2018 looking for oem choke control cable for my 73' 16h hydro no name. PO had installed an aftermarket style control cable which is now becoming difficult to operate. id like to remove said cable and install an orginal to have choke operation as intended from factory. ive searched the bay and around this site and cannot find what i need. any input would be much appreciated thanks j- Share this post Link to post Share on other sites
BOB ELLISON 2,983 #2 Posted March 15, 2018 I have a 74 c160 which is almost identical to yours . What I had to do is but a universal cable and add it to the original handle. The cable is not available from Toro . 1 1 Share this post Link to post Share on other sites
JPWH 6,542 #3 Posted March 15, 2018 Do you need the whole assembly or just the cable and conduit. I may have everything but the t handle. Glen Pettit in the vendor section sells the handle. 2 Share this post Link to post Share on other sites
classicdmax 190 #4 Posted March 15, 2018 Just need cable and conduit, but will take whole assembly if necessary. Bought T handle a couple years back but had been waiting to install it until I got the choke properly operational Share this post Link to post Share on other sites
classicdmax 190 #6 Posted March 15, 2018 (edited) Can anyone provide any input concerning routing of oem choke cable. All I have remaining of existing is a stub coming from under fuel tank or length? thanks Edited March 16, 2018 by classicdmax Share this post Link to post Share on other sites
peter lena 9,771 #7 Posted March 16, 2018 hello, having replaced both of my control cables with new, throttle and choke , I picked up longer cables for each , giving me more cable for a smoother routing, I have found that cables want to sit in a smoother run, making it naturally work smoother. also before using the new cable I always pull out the inner cable from the wire wrap and (cable fluid film ) it hanging vertically, insuring no binding or drag. I find its the small details that help/make a number of control issues on the horse work without effort. often, a sloppy control rod fit is quickly fixed with a thick washer and lubricant. just my own experience . pete 1 Share this post Link to post Share on other sites
