ezeastside 93 #1 Posted March 6, 2018 I am having trouble finding the bearing for the machine mounted deck pulley on my 1077. The parts breakdown only shows the part # of the whole pulley (1623) but its a cast pulley and the bearing pressed out easy. From what I can tell the bearing should be .375" x 1.375". I found the new replacement pulley on line for $54 ouch!! Any direction would be appreciated!! ED Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,730 #2 Posted March 6, 2018 This was once posted but verify to make sure it is correct V-idler pulley - 3.062" OD - 1623 replaced by 92-7102 (Generic 1614ZZ bearing Used in belt idler for 5-2321 deck) This pulley may also work V-idler pulley - 3.062" OD - 109444 (Napa 7-05491) 3.0625" OD x .375" ID for 1/2" belt Garry 3 Share this post Link to post Share on other sites
Sarge 3,470 #3 Posted March 6, 2018 If you have a micrometer or good pair of calipers you could search for a replacement dimensionally. Sarge Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,730 #4 Posted March 6, 2018 Looks like the 1614 has a 1-1/8" OD. Garry Share this post Link to post Share on other sites
groundhog47 347 #5 Posted March 6, 2018 If I understand you've resourced local bearing supply houses and drew a blank. I would try the bid auction site, have had very good luck finding bearings there. Does/did it have a snap ring retainer? Also if it has any legible Torrington or other number you can find visible might be of great benefit. 1 Share this post Link to post Share on other sites
Rideawaysenior 28 #6 Posted March 7, 2018 (edited) Ed, Best suggestion I have is to take the old bearing and take a ride to Springfield, MA to EB Atmus. It's not exactly in your back yard but not that far either. I just rebuilt my deck on the charger 10 and the spindle bearings cost me about $25 each and they have them on the shelf. Jack Edited March 7, 2018 by Rideawaysenior Share this post Link to post Share on other sites
wheelhorseman 3,241 #7 Posted March 7, 2018 I have them https://www.wheelhorsepartsandmore.com/belts.html#!/Toro-Wheel-Horse-1623-92-7102-Pulley/p/91798930/category=23610643 1 Share this post Link to post Share on other sites
ezeastside 93 #8 Posted March 7, 2018 Thank you for all the suggestions. Although the parts breakdown for the pulley says it is part # 1623, the pulley itself has 4974 stamped on it. I don't have a micrometer only a inexpensive set of calipers. I still think the bearing is as I mentioned .375 ID and 1.375 OD I have searched over the web in several places and even went to Napa and another local auto parts store with no luck. Still as suggested by rideaway I could try EB Atmus. I am hoping to keep the cast pulley for originality but I see I have the option from Wheelhorsman. I have some time yet to procure as the deck is next after the restore of the tractor is finished. Hopefully I will post a full resto soon. 1 Share this post Link to post Share on other sites
wheelhorseman 3,241 #9 Posted March 7, 2018 4 minutes ago, ezeastside said: Thank you for all the suggestions. Although the parts breakdown for the pulley says it is part # 1623, the pulley itself has 4974 stamped on it. I don't have a micrometer only a inexpensive set of calipers. I still think the bearing is as I mentioned .375 ID and 1.375 OD I have searched over the web in several places and even went to Napa and another local auto parts store with no luck. Still as suggested by rideaway I could try EB Atmus. I am hoping to keep the cast pulley for originality but I see I have the option from Wheelhorsman. I have some time yet to procure as the deck is next after the restore of the tractor is finished. Hopefully I will post a full resto soon. I have replacement bearings for your cast pulley - I don’t have them listed yet I will try to get them listed today. Share this post Link to post Share on other sites
