Nick Anderson 4 #1 Posted March 6, 2018 I’ve recently had trouble with my kholer K301s model motor off of my Wheel Horse 1277. The only reason I know it’s a K301s model is from doing some research and I need to know what the specs are but my identification tag is completely worn out. Any ideas on what I can do to figure out how to identify it or get parts for it? Share this post Link to post Share on other sites
953 nut 63,916 #2 Posted March 6, 2018 The Spec number for your engine is 4712B presuming it is the engine that came with the tractor. 2 Share this post Link to post Share on other sites
Nick Anderson 4 #3 Posted March 6, 2018 35 minutes ago, 953 nut said: The Spec number for your engine is 4712B presuming it is the engine that came with the tractor. How did you find that? Share this post Link to post Share on other sites
953 nut 63,916 #4 Posted March 6, 2018 Looked it up on this list. wheelhorseallyears.pdf Share this post Link to post Share on other sites
Achto 30,828 #5 Posted March 6, 2018 (edited) Fortunately, You don't really need the specific model number in order to get most of the parts that you need for your engine. As long as you know that it is a k301. Here are some links for rebuild kits. First offers OEM as well as aftermarket kits. http://www.psep.biz/store/kohler_rebuild_kits.htm This kit provides a few extra items http://isavetractors.com/the-ultimate-engine-restoration-rebuild-kit-kohler-k301-12hp/ If you just need some repair parts, looking up k301 will most likely help you find what you need. Edited March 6, 2018 by Achto 1 Share this post Link to post Share on other sites
Ed Kennell 44,631 #6 Posted March 6, 2018 To positively ID the engine, measure the bore. K301= 3.375". BTW, the cylinder bore and crank must be accurately measured BEFORE ordering parts. 1 Share this post Link to post Share on other sites
richmondred01 2,333 #7 Posted March 7, 2018 (edited) Like ed said measure the bore. Also the pto side may have embossed the block size. However, it’s not always 100% because some k241 actually have the k301 block. also many don’t have anything embossed. At the end of the day measure the inside of the bore. That will give you a starting point. If you don’t have an inside mic or a telescopic gauge, I recommend you take it to a machine shop. Edited March 7, 2018 by richmondred01 Share this post Link to post Share on other sites
