diesel life 42 #1 Posted March 5, 2018 Hey guys just wandering if anyone has ever had there deck powder coated?? Just got a deck and am sanding it down but thought that maybe powder coat would last longer than the paint. Any input is welcomed thanks in advance... Share this post Link to post Share on other sites
Duramax7man7 506 #2 Posted March 5, 2018 I'll tell you what might work really well from personal experience... This stuff is pretty durable and with a hi-gloss underneath the deck it should make for easy cleaning. I used plan ole Rustoleum 2X Orange on a Snowmobile hood this past fall and then covered it with some "Spray-Max 2K Hi-Gloss" 2 part epoxy... Turned out beautiful. It was really put to the test this winter. Albeit, by an unforeseen incident. I was heading up a berm and a sway bar link busted and I lost a bit of traction heading up over it and tipped the sled into a brush line with pricker bushes... I thought for sure that I would be repainting the hood again this summer. NOT A SCRATCH ON IT!!!! I was Blown away to say the least! The hood being composite, I used self etching primer and then let base coat dry for 8 days (Rustoleum says 5-7) and then scuffed up the base coat with some grey scuffing pad from Autozone. Then I hit the hood with 4 coats of this hi-gloss 2 part epoxy and let it dry for a week and then a month later this incident happened. It comes in Matte, Semi-Matte (Semi-Gloss) and Hi-Gloss formulas. Check out the finish of this stuff without me even wet sanding or buffing it. So I would consider something like this or spray on truck bed liner.... Hitting sticks and rocks though will damage any paint job. Not sure if powder coating will hold up any better or not. 1 Share this post Link to post Share on other sites
WHNJ701 4,168 #3 Posted March 6, 2018 last couple decks I redid, I brushed gloss rustoleum on the underside and for the top/outer just automotive primer and paint to match the tractor, the high gloss on the underside makes nice easy cleanup 2 Share this post Link to post Share on other sites
oliver2-44 11,075 #4 Posted March 6, 2018 I hand brushed 2 coats of POR 15 on the bottom side of my 312 deck. It has lasted 2 long Texas mowing season with so signs of wear. Nice slick coating 1 Share this post Link to post Share on other sites
diesel life 42 #5 Posted March 6, 2018 10 hours ago, Mastiffman said: I'll tell you what might work really well from personal experience... This stuff is pretty durable and with a hi-gloss underneath the deck it should make for easy cleaning. I used plan ole Rustoleum 2X Orange on a Snowmobile hood this past fall and then covered it with some "Spray-Max 2K Hi-Gloss" 2 part epoxy... Turned out beautiful. It was really put to the test this winter. Albeit, by an unforeseen incident. I was heading up a berm and a sway bar link busted and I lost a bit of traction heading up over it and tipped the sled into a brush line with pricker bushes... I thought for sure that I would be repainting the hood again this summer. NOT A SCRATCH ON IT!!!! I was Blown away to say the least! The hood being composite, I used self etching primer and then let base coat dry for 8 days (Rustoleum says 5-7) and then scuffed up the base coat with some grey scuffing pad from Autozone. Then I hit the hood with 4 coats of this hi-gloss 2 part epoxy and let it dry for a week and then a month later this incident happened. It comes in Matte, Semi-Matte (Semi-Gloss) and Hi-Gloss formulas. Check out the finish of this stuff without me even wet sanding or buffing it. So I would consider something like this or spray on truck bed liner.... Hitting sticks and rocks though will damage any paint job. Not sure if powder coating will hold up any better or not. Wow man than stuff has held up real well even with your accident.... 1 Share this post Link to post Share on other sites
diesel life 42 #6 Posted March 6, 2018 (edited) Thanks for the feedback guys, i had thought about using por15 on the underside then priming and spraying the top with bedliner and then spraying the red and seeing how long that last... also guys what red color best matches the wheel horse red??? Edited March 6, 2018 by diesel life 1 Share this post Link to post Share on other sites
oliver2-44 11,075 #7 Posted March 6, 2018 I use Rustoleum Regal Red and Rustoleum Linen on the rims. Others will be along with a few other color choices. PS be cautious using the Tractor Supply "Majic" brand tractor equipment enamel. Many of us find it dries very slid and doesn't get very hard Share this post Link to post Share on other sites
diesel life 42 #8 Posted March 6, 2018 6 hours ago, oliver2-44 said: I use Rustoleum Regal Red and Rustoleum Linen on the rims. Others will be along with a few other color choices. PS be cautious using the Tractor Supply "Majic" brand tractor equipment enamel. Many of us find it dries very slid and doesn't get very hard Thanks for the info, much appreciated Share this post Link to post Share on other sites
don 76 wheel horse 24 #9 Posted March 15, 2018 Good info but i still cannot find color match for my wheel horse original part clovis hitch to the rest of tractor.. any one know of a farm equipment store that will match paint. don Share this post Link to post Share on other sites
Duramax7man7 506 #10 Posted March 15, 2018 If you are trying match faded or paint with patina on it, that's going to be hard... Share this post Link to post Share on other sites
BOB ELLISON 2,981 #11 Posted March 15, 2018 Maybe NAPA can match it if you have a spray gun. I used Regal red also, but others say IH Red is close also Share this post Link to post Share on other sites
Digger 66 3,488 #12 Posted March 15, 2018 On 3/5/2018 at 7:35 PM, jabelman said: last couple decks I redid, I brushed gloss rustoleum on the underside and for the top/outer just automotive primer and paint to match the tractor, the high gloss on the underside makes nice easy cleanup If you can have a deck in your living room , I won't feel so bad when I bring my 4 wheeler clutch inside and scrub it in the laundry tubs ! Share this post Link to post Share on other sites
WHNJ701 4,168 #13 Posted March 16, 2018 On 3/15/2018 at 5:58 PM, Digger 66 said: If you can have a deck in your living room , I won't feel so bad when I bring my 4 wheeler clutch inside and scrub it in the laundry tubs ! yes I have one cool wife! not the living room, I haven't tried yet. its the finished basement/kids play room Share this post Link to post Share on other sites
WHNJ701 4,168 #14 Posted March 16, 2018 On 3/15/2018 at 12:23 AM, don 76 wheel horse said: Good info but i still cannot find color match for my wheel horse original part clovis hitch to the rest of tractor.. any one know of a farm equipment store that will match paint. don that deck photo I posted is regal red Share this post Link to post Share on other sites
