formariz 12,381 #1 Posted February 16, 2018 The RJ fuel tank isnot an easy item to come by. I have however found a few usable ones by looking for vintage go kart fuel tanks. Some are identical to the RJ tank and they do show up once in a while.In the two in the photo , the tanks is exactly the same size and bung location are within 1/2" of RJ tank. Drain holes are also close but those are not as critical.Filler neck is identical in one and slightly higher in the other( its actually a better one to use). I tried them and they work great. These particular two are flawless inside and out . 6 1 Share this post Link to post Share on other sites
WHX?? 57,470 #2 Posted February 16, 2018 Care to share your source? Share this post Link to post Share on other sites
Mike'sHorseBarn 3,605 #3 Posted February 16, 2018 11 minutes ago, WHX14 said: Care to share your source? Share this post Link to post Share on other sites
formariz 12,381 #4 Posted February 16, 2018 10 minutes ago, WHX14 said: Care to share your source? eBay. I always search for vintage go kart fuel tanks. 1 Share this post Link to post Share on other sites
953 nut 67,517 #5 Posted February 16, 2018 47 minutes ago, formariz said: eBay. I always search for vintage go kart fuel tanks. Now that you have divulged your secret stash we will all be out there bidding against you. 1 1 Share this post Link to post Share on other sites
formariz 12,381 #6 Posted February 16, 2018 2 minutes ago, 953 nut said: Now that you have divulged your secret stash we will all be out there bidding against you. If you cant find them , its because there is already a big stash here. 1 2 Share this post Link to post Share on other sites
