ebinmaine 80,973 #327 Posted February 3, 2019 As you can see in the pictures above this one ... Trina spent some time putting the first coat of white on a few of the engine tins and other pieces. The inside of this flywheel cover is flat black instead of continuing the Navajo White theme on the inside of the cover because that way the unpainted flywheel will blend in better. 1 2 Share this post Link to post Share on other sites
Pullstart 71,381 #328 Posted February 4, 2019 I miss working on Frank. Thanks for giving us the play by play, this tractor is more exciting than any big game that aired yesterday... 2 1 Share this post Link to post Share on other sites
ebinmaine 80,973 #329 Posted February 5, 2019 A little more painting tonight. Engine cover, starter. I started installing the wire harness as well. 2 2 Share this post Link to post Share on other sites
19richie66 17,937 #330 Posted February 5, 2019 Looking good Eric! 1 Share this post Link to post Share on other sites
ebinmaine 80,973 #331 Posted February 7, 2019 Starter, fuel pump, carb and all tins on the engine now. 4 3 Share this post Link to post Share on other sites
Pullstart 71,381 #332 Posted February 7, 2019 19 hours ago, ebinmaine said: That hood..... is so cool. 1 1 1 Share this post Link to post Share on other sites
LengerichKA88 1,885 #333 Posted February 7, 2019 Looking good! 1 Share this post Link to post Share on other sites
ebinmaine 80,973 #334 Posted February 7, 2019 1 minute ago, pullstart said: That hood..... is so cool. Thanks man. My honey's paint work. I'll mention it to her. 1 Share this post Link to post Share on other sites
Pullstart 71,381 #336 Posted February 9, 2019 Hey Eric, where did you and Trina get those fancy throttle linkages? 1 Share this post Link to post Share on other sites
ebinmaine 80,973 #337 Posted February 9, 2019 6 minutes ago, pullstart said: Hey Eric, where did you and Trina get those fancy throttle linkages? All stock stuff for this tractor Kev. Just polished all that on the wire wheel. 1 2 Share this post Link to post Share on other sites
Pullstart 71,381 #338 Posted February 9, 2019 Huh. They look nice, I figured race car catalogs! 1 Share this post Link to post Share on other sites
ebinmaine 80,973 #339 Posted February 10, 2019 So I said to my Honey I was thinking about trying to draw out the word KOHLER on the side of the engine. We talked about a couple different ways to go about doing it and then she took some cinnamon paint and a brush and... 5 4 1 Share this post Link to post Share on other sites
PeacemakerJack 11,074 #340 Posted February 10, 2019 Looking totally sweet there Eric and Trina—loving what you are doing with the cinnamon horse—the detail is great! I see that full depth air cleaner looks right at home on there with the fresh matching paint. The red letters on the white painted engine tin is gonna pop when the cinnamon hood is in place...can’t wait! 1 2 Share this post Link to post Share on other sites
AMC RULES 37,260 #341 Posted February 10, 2019 Wondering if all those wire wheeled details been clear coated? 1 Share this post Link to post Share on other sites
ebinmaine 80,973 #342 Posted February 10, 2019 10 minutes ago, PeacemakerJack said: red letters on the white painted engine Thanks Josh! Those letters are the same cinnamon color as the rest. She sprayed some cinnamon paint into the cap of a small bottle and then used a paint brush to apply the paint to the engine using tiny modeling brushes. Couple more things painted this evening by Trina. The fuel tank is a 1.2 gallon tank from the auction pile. Believed to be from a mid-1960s Jacobsen or simplicity. 1 1 Share this post Link to post Share on other sites
ebinmaine 80,973 #343 Posted February 10, 2019 3 minutes ago, AMC RULES said: Wondering if all those wire wheeled details been clear coated? Nothing on them yet Craig... I hadn't made up my mind if I was going to just spray all of those the same color as the engine. Share this post Link to post Share on other sites
AMC RULES 37,260 #344 Posted February 10, 2019 Painting will provide your best bet for rust protection, simply clearing them won't get it done Eric. Especially on a working tractor that spends any time out in the weather. 1 Share this post Link to post Share on other sites
Lee1977 7,805 #345 Posted February 10, 2019 (edited) You are going to have to get a bigger gas tank. That 16 is going to suck that thing dry the first time you open the throttle. Might even pull a vacuum on the tank and suck the gas cap inside. Edited February 10, 2019 by Lee1977 3 Share this post Link to post Share on other sites
Tractorhead 9,217 #346 Posted February 10, 2019 Eric, you and trina did a good job. I like the Color incl. The differently colored Kohler sign., it gives the Engine a bit more personality. It looks like fresh out from Factory, awesome job. 1 1 Share this post Link to post Share on other sites
SylvanLakeWH 32,706 #347 Posted February 10, 2019 Looking very nice! 1 Share this post Link to post Share on other sites
ebinmaine 80,973 #348 Posted February 11, 2019 I did a bit more wiring Sunday morning. Installed the voltmeter and voltage regulator. I ran extra ground wires from the condenser, voltmeter, and voltage regulator direct to the battery. A little extra insurance where there's so much new paint. Trina put the rest of the sheet metal on. We'll pop them back off to change the engine pulley at some point but we have all the nuts/bolts found and wire brushed now. We used some wet/dry sandpaper for step gripper. 2 6 Share this post Link to post Share on other sites
953 nut 69,834 #349 Posted February 11, 2019 2 hours ago, ebinmaine said: I ran extra ground wires from the condenser, voltmeter, and voltage regulator direct to the battery. A little extra insurance where there's so much new paint. Great Idea, wish more would do that. 1 1 Share this post Link to post Share on other sites
classiccat 548 #350 Posted February 11, 2019 +1 on the ground node! Awesome color scheme; she's looking super sweet! ....literally... hungry for a hot cinnabun with extra icing! 3 Share this post Link to post Share on other sites
