bunson70 51 #1 Posted January 25, 2018 I've been kicking around the idea of adding two Amber led lights to the front, and two to the back of my Commando 8. I would like to have them flash on and off. Does anyone know if a standard turn signal flasher will work? Or, do I need a different flasher unit? Share this post Link to post Share on other sites
cleat 8,255 #2 Posted January 25, 2018 You will need a low current LED compatible flasher. Not a big deal as they are readily available, I have them in a couple of my vehicles. I bought mine on ebay. Cleat 4 Share this post Link to post Share on other sites
KC9KAS 4,745 #3 Posted January 25, 2018 With the lower current draw of LED lights, a standard flasher will not work. 4 Share this post Link to post Share on other sites
953 nut 63,504 #4 Posted January 25, 2018 One of many on the internet. https://www.superbrightleds.com/moreinfo/car-install-supplies/fl2-red-led-bulb-electronic-flasher/779/833/?utm_source=googlebase&utm_medium=base&utm_ 4 Share this post Link to post Share on other sites
shallowwatersailor 3,216 #5 Posted January 25, 2018 Try either of these. You just need to run wires to power them. https://www.superbrightleds.com/moreinfo/strobe-fixtures/low-profile-vehicle-led-mini-strobe-light-head-single-or-dual-color-18-watt/3458/ https://www.superbrightleds.com/moreinfo/strobe-fixtures/9-watt-vehicle-mini-strobe-light-head/3457/ 4 Share this post Link to post Share on other sites
bunson70 51 #6 Posted January 27, 2018 Awesome, thank you!! Share this post Link to post Share on other sites
KC9KAS 4,745 #7 Posted January 27, 2018 I actually installed an alternating flasher on my GT-14 so the rear facing red LED lights alternated when flashing! Share this post Link to post Share on other sites
edgro 680 #8 Posted February 4, 2018 If you look at auction for Flashing motorcycle brake lights, you will find these I put one on each side of tractor for having to back out into the street to clear the driveway camera don't seem to like them, here is video flashing against the shed MVI_1376.MOV 3 Share this post Link to post Share on other sites
