snowhound 106 #1 Posted January 18, 2018 I'm looking at a GT-1600 that has a manual lift that doesn't hold, that is when the lift arm is pulled back to raise the snowblower it doesn't lock. How much of a job is it to replace the lock mechanism? Share this post Link to post Share on other sites
Racinbob 12,895 #2 Posted January 18, 2018 It's not difficult but I'd suggest disconnecting the blower and trying it that way. It's pretty easy to have something out of adjustment and the blower stops the travel before it can latch. 2 1 Share this post Link to post Share on other sites
Ed Kennell 45,727 #3 Posted January 18, 2018 Could be the lift/push rod is a tad too long. 3 Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,145 #4 Posted January 18, 2018 Illustrated parts list help? Garry 1 Share this post Link to post Share on other sites
JimmyJam 542 #5 Posted January 19, 2018 While we are on the topic of "manual lift for attachments" (may be a bit ). However, I am looking for the WH illustration of the manual lift (rock shaft) that shows what holes are intended for. ie: deck, plow, snowblower etc. I tried looking in Manual section with no eval. I did see that illustration some time back. Just can't find it now. Any HELP would be appreciated. Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,145 #6 Posted January 19, 2018 2 hours ago, JimmyJam said: While we are on the topic of "manual lift for attachments" (may be a bit ). However, I am looking for the WH illustration of the manual lift (rock shaft) that shows what holes are intended for. ie: deck, plow, snowblower etc. I tried looking in Manual section with no eval. I did see that illustration some time back. Just can't find it now. Any HELP would be appreciated. Some of the tractor parts lists have what you are referring to I think. Believe there are named manual lift linkage or hydraulic lift linkage. Page 22 of the manual above for the GT models have this same page. Garry 1 Share this post Link to post Share on other sites
