sqrlgtr 3,541 #25951 Posted May 10 1 minute ago, ML3 said: Thanks. I really tried to make it as subtle as possible. Took very little modification to make it work. It clatters & rolls coal. Had to remove & make/modify exhaust, air filter, crank breather, & fuel overflow reservoir. Didnt wanna drill/tap original fuel tank. Ebay diesel. Think its the same on Amazon. It has a decompression lever. Its hard starting in cold weather but if its over 60° it always starts on the 1st pull. I will have to check them out really have soft spot for diesels. Share this post Link to post Share on other sites
ebinmaine 79,955 #25952 Posted May 10 44 minutes ago, WHX?? said: The holes would just not line up and 38 minutes ago, ineedanother said: I need to do another. Did it once without too much trouble but I remember one of the four fighting a bit. I just make Trina install em.... Right...... "Make" & "Trina" anything. 🥋 4 Share this post Link to post Share on other sites
ML3 2,442 #25953 Posted May 10 Just now, sqrlgtr said: I will have to check them out really have soft spot for diesels. Its the 2nd one I installed. 1st one was in a RJ. I never completed it & sold it at a local show to a guy from out of state. He offered me too much $$ to say no. 3 Share this post Link to post Share on other sites
sqrlgtr 3,541 #25954 Posted May 10 2 minutes ago, ML3 said: Its the 2nd one I installed. 1st one was in a RJ. I never completed it & sold it at a local show to a guy from out of state. He offered me too much $$ to say no. what kind of HP are they? I have got a few extra 400 Suburban parts laying around (hood,frame,frontaxle etc.) and was thinking of making some sort of custom out of them and thought a diesel would be interesting to use. 2 Share this post Link to post Share on other sites
Achto 32,186 #25955 Posted May 10 1 hour ago, ineedanother said: Canceled date night with the wife Understanding wife or brave man. Either way that usually don't end well. 1 7 Share this post Link to post Share on other sites
WHX?? 57,601 #25956 Posted May 10 1 hour ago, ebinmaine said: I just make Trina install em.... Well now just ain't you a regular freakin hero... 1 5 Share this post Link to post Share on other sites
Achto 32,186 #25957 Posted May 10 1 hour ago, WHX?? said: Not only that @Achto busted a brand new piston ring and invented some brand new french. Sad but true. Got up early this morning in hopes to wrap up an engine rebuild. Got to the point of installing the rings on the piston. Bottom ring went well, got to the second ring and of course it dropped in the top groove. Was carefully walking it around and.......snap. After the words of choice stopped I lit a thinking stick and went for about a 1/4 mile walk to calm down. Well as they say "Crap happens". I'm over it, new parts are on the way, hopefully next time will turn out better. 5 2 Share this post Link to post Share on other sites
ineedanother 2,686 #25958 Posted May 10 2 minutes ago, Achto said: I lit a thinking stick 1 Share this post Link to post Share on other sites
C100guy94 116 #25959 Posted May 10 On 5/6/2026 at 9:04 PM, WHX?? said: Set a camera up on the cat food what to see was eating it and got this ... Well the nice thing about trail cameras is this horse pic ... Moved the trail cam to the asparagus patch to see if deer were eating that ... It was what they call a bluebird day. That bird just did a drive by and a posser I'd say. Lol 1 Share this post Link to post Share on other sites
ebinmaine 79,955 #25960 Posted May 10 10 hours ago, WHX?? said: Well now just ain't you a regular freakin hero... Yyyeppp 1 Share this post Link to post Share on other sites
Ed Kennell 46,764 #25961 Posted May 10 On 5/6/2026 at 9:04 PM, WHX?? said: Moved the trail cam to the asparagus patch to see if deer were eating that ... It was what they call a bluebird day. That's an amazing photo. Muddy makes a much higher speed and quality camera than I have. 1 Share this post Link to post Share on other sites
ML3 2,442 #25962 Posted May 10 15 hours ago, sqrlgtr said: what kind of HP are they? I have got a few extra 400 Suburban parts laying around (hood,frame,frontaxle etc.) and was thinking of making some sort of custom out of them and thought a diesel would be interesting to use. Advertised as 3hp. Power seems more than adequate but only work it may see is hauling a yard cart around. I did it more for cruising at shows & to do something different, other than a Predator. Most important thing to do is prime the injection pump before trying to start for the 1st time. Share this post Link to post Share on other sites
Tuneup 1,459 #25963 Posted May 10 Son called to say the '76 C120 stalled down in the meadow. They mow it about once a month - hard on the 42RD. The left wheel mount had snapped a month ago and I welded it. All seemed fine then. I had refurbished the K301 and trans about 10 years ago. She's a beast - can't have many hours, though I pulled it from the backyard of an old church friend where it sat for many years. I brought the 516 over and the 48SD finished it for them. Well, the RD was soaked with oil. Found that I had not torqued the oil pan. The bolts loosened and the gasket blew. Luckily, the stall wasn't a seize. The fuel pump - a Briggs-like pulse pump - filled with oil and starved it for fuel before it would starve for oil. Phew! We're lucky that way. Pulled the engine, replaced the gasket and refreshed the deck a bit. Good time for the youngest to see how. All good and ready for another season in the meadow. I was sure to check the rod and balance gears to ensure my brain hadn't failed there. Close one! 6 Share this post Link to post Share on other sites
WHX?? 57,601 #25964 Posted May 11 (edited) 12 hours ago, Ed Kennell said: That's an amazing photo. Muddy makes a much higher speed and quality camera than I have. These were really cheap ones too. Two for like $80. I was plowing a furrow for planting more asparagus roots for this one. Second pic is a Wild Game camera at the end of the field. Edited May 11 by WHX?? 5 1 Share this post Link to post Share on other sites
squonk 47,585 #25965 Posted May 11 On 5/9/2026 at 9:51 PM, Achto said: Sad but true. Got up early this morning in hopes to wrap up an engine rebuild. Got to the point of installing the rings on the piston. Bottom ring went well, got to the second ring and of course it dropped in the top groove. Was carefully walking it around and.......snap. After the words of choice stopped I lit a thinking stick and went for about a 1/4 mile walk to calm down. Well as they say "Crap happens". I'm over it, new parts are on the way, hopefully next time will turn out better. Just say " Waka Flocka! 4 Share this post Link to post Share on other sites
ebinmaine 79,955 #25966 Posted May 11 I'm at work. Trina's home having fun. 3 1 Share this post Link to post Share on other sites
SylvanLakeWH 31,913 #25967 Posted May 11 51 minutes ago, ebinmaine said: I'm driving around. Trina's home working and having fun... Fixed it for ya... 4 1 Share this post Link to post Share on other sites
C100guy94 116 #25968 Posted May 11 1 hour ago, ebinmaine said: I'm at work. Trina's home having fun. Same here buddy at work. Wish I was having fun 1 Share this post Link to post Share on other sites
Chris689 308 #25969 Posted May 12 The wife wanted one of the daycare play scapes relocated in the yard now that we’re down to two of them from three. 4 1 Share this post Link to post Share on other sites
MainelyWheelhorse 2,974 #25970 Posted May 12 This afternoon I swapped a center spindle out as the idler swap didn’t change the noise from the deck. It is better but I’ll have to mow with it to see if anything changed. At least now I know the center spindle, and idler are greased and both seem to be good. The only other rotating parts are the two outer spindles which they’ll be the next thing to be swapped. I’m at least going to check them out and give them a good clean out if not swap them. I’m just curious though how much noise should these 3 blade 42”deck make? If it’s a hum I’d be good with that. Before I started swapping parts I couldn’t hear the engine at all over the deck. 3 1 Share this post Link to post Share on other sites
Chris689 308 #25971 Posted May 12 29 minutes ago, MainelyWheelhorse said: If it’s a hum I’d be good with that. Before I started swapping parts I couldn’t hear the engine at all over the deck. My 42RD is just barely audible over the engine noise with stock exhaust. The deck has a very mild hum. 1 1 Share this post Link to post Share on other sites
CasaytheMann 231 #25972 Posted May 12 2 hours ago, MainelyWheelhorse said: This afternoon I swapped a center spindle out as the idler swap didn’t change the noise from the deck. It is better but I’ll have to mow with it to see if anything changed. At least now I know the center spindle, and idler are greased and both seem to be good. The only other rotating parts are the two outer spindles which they’ll be the next thing to be swapped. I’m at least going to check them out and give them a good clean out if not swap them. I’m just curious though how much noise should these 3 blade 42”deck make? If it’s a hum I’d be good with that. Before I started swapping parts I couldn’t hear the engine at all over the deck. Those two blades look beat up. Have you checked them to see if they are balanced? 4 1 Share this post Link to post Share on other sites
MainelyWheelhorse 2,974 #25973 Posted May 12 @CasaytheMann No,, not yet but that will be the next thing. Share this post Link to post Share on other sites
Handy Don 17,107 #25974 Posted May 12 3 hours ago, MainelyWheelhorse said: @CasaytheMann No,, not yet but that will be the next thing. Dull and/or unbalanced equals strain on the deck through load, drag, and vibration. Vibration = NOISE! 1 Share this post Link to post Share on other sites
MainelyWheelhorse 2,974 #25975 Posted May 12 (edited) In the ongoing saga of the mowing decks, I swapped over to my 37”SD to mow while I fix up the 42” RD. It’s still roaring. From what I’ve had apart on the 42”RD, it seems good but I’ll give it a good once over and figure out what’s off on it. It came from the small engine graveyard up the road so who knows the last time it had maintenance. While moving things around I had help from my 9 year old nephew. He’s got it pretty down pat now. He drove both tractors and my ATV out from the basement/workshop and parked the tractors where they are in the picture. As I said before he gets a significant amount of experience with clutches and everything that goes with operating something like this so I wasn’t concerned. Edited May 12 by MainelyWheelhorse 2 Share this post Link to post Share on other sites
