Pullstart 71,329 #12151 Posted July 10, 2021 10 hours ago, 19richie66 said: Figured no one bought it at the show, may as well use it. I’d have traded you a winning raffle ticket for that! 3 Share this post Link to post Share on other sites
Maxwell-8 4,371 #12152 Posted July 10, 2021 (edited) Did a partial rewire on Amy the C-175, installing new better wires and a stronger solenoide. All conections are crimped and soldered. The previous onwer had put on a new starter. Seems to be a bit to long, as the + contactpoint was a bit to close to the oil-dipstick for my liking. piece of rubberhose fixed that as well. Edited July 10, 2021 by Maxwell-8 10 Share this post Link to post Share on other sites
19richie66 17,936 #12153 Posted July 10, 2021 (edited) Test fit 2.0 continues. I have the grille and dash raised approximately 3/8” each and the hood still hits the fuel injector lines. So..... raise it more or cut the top open just enough to let the lines poke out? Small hood bump? Decisions Edited July 10, 2021 by 19richie66 7 2 Share this post Link to post Share on other sites
peter lena 10,076 #12154 Posted July 10, 2021 @8ntruck how are the bearings and pulleys on that pto mule ? if those bearings or pulleys are worn out , that will cause a deck drive problem , slower speeds , noise . also will make belt drive tracking difficult , which might be your problem. belt. pulleys , bearings are available if thats part of your problem , pete 2 Share this post Link to post Share on other sites
ebinmaine 80,767 #12155 Posted July 10, 2021 20 minutes ago, 19richie66 said: Small hood bump? That's my vote 1 1 Share this post Link to post Share on other sites
Snoopy11 5,731 #12157 Posted July 11, 2021 Video of electric start on 51 horse Duromax... I am very happy with this! Enjoy, guys! Don 6 Share this post Link to post Share on other sites
8ntruck 9,313 #12158 Posted July 11, 2021 50 minutes ago, ebinmaine said: That's my vote Yup. Put a 'power buldge' in the hood. 1 Share this post Link to post Share on other sites
8ntruck 9,313 #12159 Posted July 11, 2021 56 minutes ago, peter lena said: @8ntruck how are the bearings and pulleys on that pto mule ? if those bearings or pulleys are worn out , that will cause a deck drive problem , slower speeds , noise . also will make belt drive tracking difficult , which might be your problem. belt. pulleys , bearings are available if thats part of your problem , pete Bearings and pulleys in the mule are fine. I only have the belt issue on the RD deck. When I run my SD deck, I don't have any issues - that's what has me thinking it is a belt issue. Share this post Link to post Share on other sites
19richie66 17,936 #12160 Posted July 11, 2021 16 minutes ago, 8ntruck said: Yup. Put a 'power buldge' in the hood. Not gonna cut it just yet. I want to get it fired up and running again just to be sure I have no issues with the engine. Then I need to make a jackshaft. Once all the mechanical is set, I’ll cut it. Thinking something like a bulge running most of the length of the hood. Thanks👍 2 Share this post Link to post Share on other sites
ebinmaine 80,767 #12161 Posted July 11, 2021 14 minutes ago, 19richie66 said: jackshaft Engine RPM runs low? Share this post Link to post Share on other sites
19richie66 17,936 #12162 Posted July 11, 2021 6 minutes ago, ebinmaine said: Engine RPM runs low? No....... engine sticks out too far to line up transmission pulley with crank pulley. I have the pulleys and shaft somewhere in my massive mess of parts. Search mission tomorrow 😁 3 Share this post Link to post Share on other sites
RandyLittrell 3,946 #12163 Posted July 11, 2021 2 hours ago, 19richie66 said: So..... raise it more or cut the top open just enough to let the lines poke out? Small hood bump? Decisions My vote is to do a hood bump, I know you would make it look right! Randy 2 1 Share this post Link to post Share on other sites
Bill Winn 157 #12164 Posted July 11, 2021 I'm sitting in my office right now and I'm supposed to be putting the finishing touches on my main message for today but I couldn't resist taking a moment to post in this thread. Yesterday, on my list of to-do's, was getting my snow plow rigged up. My C175 did not come with a rear tach-o-matic and the mounting bar on the back of the blade was removed. (so that some home made angle iron brackets with 3/4" diameter pins could be mounted in the holes where the original bar went on the blade frame.) I made up a bar held in place with 1/4" pins, got a tach-o-matic, and repaired the bottom of the blade where it had been worn down. The bottom of the blade was worn half-way into the carriage bolts. I welded an 1/8"x3" extension to the bottom of the plow and then re-mounted the wear bar upside down. It will do for now. I'm not sure what grade of steel that wear bar should be but all I have on the rack is a36 for ornamental work so I reused the stock bar. I had to fabricate a link between the lift bar and the plow but that was a simple 5 minute job. Plow goes up and down and pushes dirt. At some point I will patch up the spots where the plow sat for years in wet leaves and rusted through. The "green" cart in the background looks out of place behind the WH but it was given to me by a church member so free-to-me negates the faux pas of mismatched colors. At some point I'll set up my LPHV paint gun and shoot the whole tractor. When I do that I will buy enough paint to include the cart in the project. Hope you all have a rich day, Bill 6 3 1 Share this post Link to post Share on other sites
Lee1977 7,786 #12165 Posted July 11, 2021 12 hours ago, 19richie66 said: No....... engine sticks out too far to line up transmission pulley with crank pulley. I have the pulleys and shaft somewhere in my massive mess of parts. Search mission tomorrow 😁 13 hours ago, 19richie66 said: Not gonna cut it just yet. I want to get it fired up and running again just to be sure I have no issues with the engine. Then I need to make a jackshaft. Once all the mechanical is set, I’ll cut it. Thinking something like a bulge running most of the length of the hood. Thanks👍 Got room for a jack shaft behind the engine? Raise hood, grill and hood stand enought tto clear and extend the steering shaft up if it's too close too the hood stand. A inch or so higher with every thing won't be noticed. Share this post Link to post Share on other sites
D_Mac 9,339 #12166 Posted July 11, 2021 Nothing too exciting. Painted the bottom plow I got with the 2 tractors I pulled from the weeds. Being that I had never used the slot hitch on any of my Horses before, will the end of the plow only fit WH? 3 1 Share this post Link to post Share on other sites
19richie66 17,936 #12167 Posted July 11, 2021 (edited) 4 hours ago, Lee1977 said: Got room for a jack shaft behind the engine? Raise hood, grill and hood stand enought tto clear and extend the steering shaft up if it's too close too the hood stand. A inch or so higher with every thing won't be noticed. I moved the engine forward an inch. I did some homework and found an inch shorter oil filter so I retain enough room to be able to change the oil. I can’t go any lower or the front cover will hit the electric fan. I put the grille up an inch and it didn’t look bad but still hit the top of the lines. I couldn’t stand it so I nipped it. Hood sits level with 3/8” spacing below grille and dash stand. The jackshaft should be able to be mounted just above the steering fan gear and use the side panels for mounting it. Haven’t got that far yet. I did decide it will be a military theme build. OD green/black with white lettering. Edited July 11, 2021 by 19richie66 5 1 Share this post Link to post Share on other sites
-KC1JHB- 3 #12168 Posted July 11, 2021 Messed around/started making a plan for replacing the PTO lever on the new-to-me B80. For some reason there's still not enough engagement with the rod threaded all the way in, so it looks like I'm making a new one soon. My recent rewiring proved fruitful with starting it this time, so we should be ready to cut grass soon. Next up after the above project is to swap out the double pulley which is a universal type with the WH original I have on a second (completely shot) deck. I may try to fix this deck one day by lap welding a plate on top, because as I was grinding the holes away to get to some solid metal to weld to the deck was disappearing before my eyes. 3 Share this post Link to post Share on other sites
Pullstart 71,329 #12169 Posted July 11, 2021 38 minutes ago, -KC1JHB- said: Messed around/started making a plan for replacing the PTO lever on the new-to-me B80. For some reason there's still not enough engagement with the rod threaded all the way in, so it looks like I'm making a new one soon. My recent rewiring proved fruitful with starting it this time, so we should be ready to cut grass soon. Next up after the above project is to swap out the double pulley which is a universal type with the WH original I have on a second (completely shot) deck. I may try to fix this deck one day by lap welding a plate on top, because as I was grinding the holes away to get to some solid metal to weld to the deck was disappearing before my eyes. Got any 1 Share this post Link to post Share on other sites
Pullstart 71,329 #12170 Posted July 11, 2021 @Snoopy11 I have poor enough reception that the video won’t play nice for me... but nice shifter! Share this post Link to post Share on other sites
Pullstart 71,329 #12171 Posted July 11, 2021 We made it home from Portage, WI! Already looking forward to next year! The corn sure got tall(knee high by the Fourth of July)... and I saw another bed deck last night... 5 3 Share this post Link to post Share on other sites
8ntruck 9,313 #12172 Posted July 11, 2021 @-KC1JHB- I just went through a similar process with my PTO clutch. Turned out the outer C clip on the stub shaft in the PTO pulley had come out of the groove in the stub shaft. I cleaned the shaft, replaced the C clip and all is good. Hope this helps. 1 Share this post Link to post Share on other sites
Snoopy11 5,731 #12173 Posted July 11, 2021 2 hours ago, pullstart said: @Snoopy11 I have poor enough reception that the video won’t play nice for me... but nice shifter! Yes sir! That is the piston top out of the original Tecumseh engine. I think that reusing the piston top from the original engine is cool. The original Tecumseh had a broken piston rod... Don 1 Share this post Link to post Share on other sites
Pullstart 71,329 #12174 Posted July 12, 2021 All unloaded! 6 2 Share this post Link to post Share on other sites
balconio 606 #12175 Posted July 12, 2021 I did a bunch of small fixes to the 312-8 that I use for mowing. She has 1644 hours on the clock. - removed/pressure washed deck and greased spindles - sharpened blades - oil change (I'm commiting to doing it every 25hrs and using quality SAE30) - fixed very loose hood hinge by ditching the factory rod setup, then welding the egged out holes and redrilling them to accept 3/8" bolts with nylock nuts. Hood is completely stable now. - replaced fuel line before and after fuel pump. Also added an inline filter - drained tank and cleaned it out with the old paper towels and compressed air trick. Also replaced fuel petcock and gasket. 8 8 Share this post Link to post Share on other sites
