Bailey855 167 #11826 Posted June 12, 2021 8 hours ago, ebinmaine said: Nice little square hood. Should clean up excellent. Please post pics as you go. This will most likely be a spare parts tractor if needed. I wanted to have an extra 8hp motor for my 855 and 875 as well as a spare rear and and some good sheet metal. The front wheel weights were worth more than I paid for the lot lol 3 Share this post Link to post Share on other sites
Wheel Horse 3D 3,821 #11827 Posted June 13, 2021 (edited) A bit more progress on tires and wheels! Still waiting for the weights to dry well. Replaced the 4 front wheel bearings(only a 50 mile round trip for those!). Still need another shim washer or 2. Did some flex seal spray seat patching, and of course another wd40 spray down! Edited June 13, 2021 by Wheel Horse 3D 7 2 Share this post Link to post Share on other sites
Wheel Horse 3D 3,821 #11828 Posted June 13, 2021 And a before and after..Dug when we picked him up, and now. 8 7 Share this post Link to post Share on other sites
ebinmaine 72,434 #11829 Posted June 13, 2021 1 hour ago, Wheel Horse 3D said: .Dug Nice work Sir 👍 Share this post Link to post Share on other sites
Wheel Horse 3D 3,821 #11830 Posted June 13, 2021 25 minutes ago, ebinmaine said: Nice work Sir 👍 Thank you sir..nothin fancy or uber perfect just a maintenance and freshen. 2 Share this post Link to post Share on other sites
Thor27 835 #11831 Posted June 13, 2021 I've been chasing a big oil leak on my M18. I thought it was the drain pipe so I pulled the engine off last weekend, removed the drain completely, put it back together and it marked it's spot again all week. I put this together from a MV18 and some ebay parts, so took I it personal... found a wet hole in the rear of the bearing cover below the pulley. Looked at my 418-8 and saw that hole has a bolt in it. So I tapped it and put a header bolt in it. So far so good. Put some weights on, My wheels are made from miller blanks, wish I'd have used Wheel Horse centers. If it had straight centers with a broached hole it would have been about an hour quicker, but... 13" pieces of all thread and some juggling got me 90# more per wheel. 5 5 Share this post Link to post Share on other sites
Wheel Horse 3D 3,821 #11832 Posted June 13, 2021 Burn some late night oil and Finish reinstallation of weights..design a 6in(5 7/8) snap in hubcap for the wheel weights... 10 2 Share this post Link to post Share on other sites
Oldskool 6,663 #11833 Posted June 13, 2021 This morning's project is making a Wheel Horse/garden tractor work area in the shop. I have to many things in and out of here. Anything from mini bikes to lawn tractors to automobiles. Things are getting mixed together to much. 11 1 Share this post Link to post Share on other sites
ebinmaine 72,434 #11834 Posted June 13, 2021 21 minutes ago, Oldskool said: making a Wheel Horse/garden tractor work area A lovely idea. May want to consider a transmission holder hole like I have on mine. 2 1 Share this post Link to post Share on other sites
Tuneup 1,452 #11835 Posted June 13, 2021 (edited) So, Friday finally had enough time without rain for me to mow the back lot - a mess of weeds and southern grasses and 35° declines that I run along the angle. The 516H can do this with washer fluid in the tires and with me sitting on the side, albeit slowly. I grew up this way - the old Simplicity mowing along the angle and me on the side of the seat. I hate mowing soggy grass. Like to preserve these decks forever. When I first got her, she'd die on inclines. Couldn't figure it out BUT, it went away. Could be good or could be bad. Yesterday, it appeared again. Sad - 1/2 tank on the newly cleaned and tightened fuel gauge circuit - was near empty. Filled the tank. Ran nice and then died in the same place. I thought dirty air filter - the foam element was dirty - removed it. Fixed it for 5 minutes again. Better filter - fixed again for 5 minutes. Did I mention that there is dirt to be mowed? Hard to keep the elements clean. Back to the garage and replaced the fuel pump with the 520's - the former owner had a similar problem but there was hope. Ran for 5 minutes. Sky getting black. Old pump back on. Pulled carb top - yup - almost empty. Mowed the remaining 10% down hill and then backwards back up and at lower trottle. Just can't feed fuel fast enough. Finally, routine stalls forced me to the garage for good (got there in reverse) and the rain hit. She let me down! Fuel cap has a clear hole in it. Running without the cap - no difference. Yeah, the tank valve is flowing well. The pump is just weak. I have an electric to install today from the 520's allotment of parts now that the son's brakes are replaced on the '01 Mustang which was braking on metal flakes (we're in the South - of course it's a Mustang). It's been fun! Running downhill on a low bowl will cover the main. Carb perfect - float set. Runs longer on no blades and low throttle where the pump can keep up. I'm thinking she's been a little lean forever and will like the electric pump immensely. Next time, I'll let it rain and the weed tops can make 12". I brought the old bomber out - filled the tires and sprayed Gumout into the carb until it 'took'. Old reliable took care of the last 100 sq ft and they can now sun themselves in the Georgia heat and humidity all day - gotta dry that deck now! Edited June 13, 2021 by Tuneup 2 1 Share this post Link to post Share on other sites
Oldskool 6,663 #11836 Posted June 13, 2021 2 hours ago, ebinmaine said: A lovely idea. May want to consider a transmission holder hole like I have on mine. I was thinking the samething. I'm sure there will be alot of additions as time goes on 2 Share this post Link to post Share on other sites
squonk 43,736 #11837 Posted June 13, 2021 3 hours ago, ebinmaine said: A lovely idea. May want to consider a transmission holder hole like I have on mine. And about 6 more outlets! 6 Share this post Link to post Share on other sites
squonk 43,736 #11838 Posted June 13, 2021 Went to fill the gas tank on the C-160 so I could mow the yard. The gas cap decided it didn't want to play anymore! 1 5 Share this post Link to post Share on other sites
Maxwell-8 4,367 #11839 Posted June 13, 2021 31 minutes ago, squonk said: Went to fill the gas tank on the C-160 so I could mow the yard. The gas cap decided it didn't want to play anymore! A week ago same thing happend to my pushmower. Just superglued the cap so I could mow for the day Share this post Link to post Share on other sites
Lee1977 7,189 #11840 Posted June 13, 2021 53 minutes ago, squonk said: Went to fill the gas tank on the C-160 so I could mow the yard. The gas cap decided it didn't want to play anymore! You screwed It down too tight. RED and Green could fix that right up. 1 Share this post Link to post Share on other sites
8ntruck 7,786 #11841 Posted June 13, 2021 3 hours ago, Oldskool said: I was thinking the samething. I'm sure there will be alot of additions as time goes on After recently lifting my pressure washer up onto my bench, I gave brief thought to a piece of I beam and a chain fall over the bench. Only problem is that the garage structure above the bench won't support that addition..... 1 Share this post Link to post Share on other sites
Oldskool 6,663 #11842 Posted June 13, 2021 8 minutes ago, 8ntruck said: After recently lifting my pressure washer up onto my bench, I gave brief thought to a piece of I beam and a chain fall over the bench. Only problem is that the garage structure above the bench won't support that addition..... I do have a chain fall in the big bay and a wheeled work bench. Same chainfall we use during deer season. I'm not getting any younger so working smarter not harder. That also includes cutting down on miles walked in the shop looking for tools. 2 Share this post Link to post Share on other sites
Wheel Horse 3D 3,821 #11843 Posted June 13, 2021 55 minutes ago, 8ntruck said: After recently lifting my pressure washer up onto my bench, I gave brief thought to a piece of I beam and a chain fall over the bench. Only problem is that the garage structure above the bench won't support that addition..... You could add a couple 4x4s to support either end of your i beam and fasten the tops to your lighter beams. might take up a little floor space. im gonna have to do something similar for the chain hoists.as im not sure how much weight my current roof supports will handle. For lighter stuff, ill be installing THIS the length of the shop. 2 3 Share this post Link to post Share on other sites
bigcreek 205 #11844 Posted June 13, 2021 After two days of hard rain here mid atlantic area, time to sling some grass folks this is the stud of my herd,,, yah i get to ride for four hours ,,, mowing slow 10 3 Share this post Link to post Share on other sites
cschannuth 3,817 #11845 Posted June 13, 2021 The 520H, C-161, and Lawn Ranger haven’t been out for a few months so they got some exercise today. Spread and smoothed a Little Rock at the shed. 7 4 Share this post Link to post Share on other sites
Herder 2,355 #11846 Posted June 13, 2021 9 hours ago, Oldskool said: This morning's project is making a Wheel Horse/garden tractor work area in the shop. I have to many things in and out of here. Anything from mini bikes to lawn tractors to automobiles. Things are getting mixed together to much. Be careful Oldskool, Wheel Horses are territorial and will take over all your work areas. 1 6 Share this post Link to post Share on other sites
Oldskool 6,663 #11847 Posted June 13, 2021 1 hour ago, Herder said: Be careful Oldskool, Wheel Horses are territorial and will take over all your work areas. I've noticed. They have already scared the Deeres off to the back yard and now they are trying to push the Beaver out of its home. The only one standing its ground is the Y.E.T.I. 5 Share this post Link to post Share on other sites
8ntruck 7,786 #11848 Posted June 13, 2021 @Wheel Horse 3D is that an old hay trolley? Share this post Link to post Share on other sites
Wheel Horse 3D 3,821 #11849 Posted June 13, 2021 (edited) 12 hours ago, 8ntruck said: @Wheel Horse 3D is that an old hay trolley? Yep an old cloverleaf complete with a couple different attachments....a skewer type deal, and a u shaped one that grabs from both sides Edited June 14, 2021 by Wheel Horse 3D Share this post Link to post Share on other sites
KrazeyOlDave 860 #11850 Posted June 14, 2021 Made some bling for my pony. 10 5 2 Share this post Link to post Share on other sites
