Oldskool 6,666 #9826 Posted March 20, 2021 Just mounted the front tires on gravely wheels and hubs on Hiram. 4 4 Share this post Link to post Share on other sites
OldWorkHorse 3,096 #9827 Posted March 20, 2021 Got the front bumper/hitch done on the 1257H today but still need to weld sum reinforcements to the corners but need thicker sheet steel for that. So another day. 5 3 1 Share this post Link to post Share on other sites
Tuneup 1,452 #9828 Posted March 20, 2021 (edited) Lined up my 20 gallons of washer fluid. 11 are pinkish and 9 purple. Both Wally World and both -25. Whatever. Right rear got pink. Gravity feed from a 4" PVC end cap and tap. I used a trailer strap to squeeze out air and released it. Sucked it all in. 71/2 gallons - about 45 minutes. The left had a tube so I found out something new today. Figured it would be tougher but, no. Took less time and one less gallon. At 8 lbs/gallon, the old 516 will stick to the downhills nicely now and the Eaton doesn't seem to mind. Still wheelies. Edited March 20, 2021 by Tuneup 6 1 Share this post Link to post Share on other sites
OldWorkHorse 3,096 #9829 Posted March 20, 2021 1 minute ago, Tuneup said: Lined up my 20 gallons of washer fluid. 11 are pinkish and 9 purple. Both Wally World and both -25. Whatever. Right rear got pink. Gravity feed from a 4" PVC end cap and tap. Hooked mine to a pump. She's heavy now! 4 Share this post Link to post Share on other sites
19richie66 17,763 #9830 Posted March 20, 2021 1 hour ago, Oldskool said: Just mounted the front tires on gravely wheels and hubs on Hiram. I like those! 2 1 Share this post Link to post Share on other sites
Tuneup 1,452 #9831 Posted March 20, 2021 10 minutes ago, OldWorkHorse said: Hooked mine to a pump. She's heavy now! How do you displace the air in the tire? Share this post Link to post Share on other sites
OldWorkHorse 3,096 #9832 Posted March 20, 2021 9 minutes ago, Tuneup said: How do you displace the air in the tire? Pump the fluid in after gallon or 2 hit the release button vents the air out then keep pumping do it like thst till fluid starts coming back out the tire valve then screw the pin valve back in. About 10min a tires. 4 Share this post Link to post Share on other sites
Tuneup 1,452 #9833 Posted March 20, 2021 4 minutes ago, OldWorkHorse said: Pump the fluid in after gallon or 2 hit the release button vents the air out then keep pumping do it like thst till fluid starts coming back out the tire valve then screw the pin valve back in. About 10min a tires. Gracias! A pump might be added to the list, after the welder and lathe. Welder for that deck repair. I haven't played with welding since freshman year in high school - 1977...moving the puddle along. Practice first. 3 Share this post Link to post Share on other sites
OldWorkHorse 3,096 #9834 Posted March 20, 2021 (edited) 2 minutes ago, Tuneup said: Gracias! A pump might be added to the list, after the welder and lathe. Welder for that deck repair. I haven't played with welding since freshman year in high school - 1977...moving the puddle along. Practice first. Harbor freight garden hose transfer pump and a air to water valve stem addapter kit at tractor supply. I'm new to welding to! I trust my welds for me 😆 there getting better all in good time. Oh yeah shut pump off b4 hitting the vent button! Edited March 20, 2021 by OldWorkHorse 3 Share this post Link to post Share on other sites
Oldskool 6,666 #9835 Posted March 20, 2021 53 minutes ago, 19richie66 said: I like those! I would like to think I can make my rear wheels resemble those as well 1 Share this post Link to post Share on other sites
Herder 2,355 #9836 Posted March 20, 2021 Finished up the rear tires for the 310-8, 6 gallons per tire. Almost ready for the tiller. 4 2 Share this post Link to post Share on other sites
Oldskool 6,666 #9837 Posted March 20, 2021 Ended the day by mocking up some exhaust. Bits and pieces laying around the shop. I think it will do just fine. 8 3 Share this post Link to post Share on other sites
Jhook 849 #9838 Posted March 21, 2021 Threw the plow back on for a little bit of spring cleanup in the yard today 8 1 Share this post Link to post Share on other sites
Tuneup 1,452 #9839 Posted March 21, 2021 1 minute ago, Jhook said: Threw the plow back on for a little bit of spring cleanup in the yard today Nice. That has burn pile written all over it! Share this post Link to post Share on other sites
Tach-a-matic 357 #9840 Posted March 21, 2021 2 hours ago, Tuneup said: Lined up my 20 gallons of washer fluid. 11 are pinkish and 9 purple. Both Wally World and both -25. Whatever. Right rear got pink. Gravity feed from a 4" PVC end cap and tap. I used a trailer strap to squeeze out air and released it. Sucked it all in. 71/2 gallons - about 45 minutes. The left had a tube so I found out something new today. Figured it would be tougher but, no. Took less time and one less gallon. At 8 lbs/gallon, the old 516 will stick to the downhills nicely now and the Eaton doesn't seem to mind. Still wheelies. She's heavy now! What brand string trimmer is that, and do you like it? I need new one. . 1 Share this post Link to post Share on other sites
Tach-a-matic 357 #9841 Posted March 21, 2021 new battrey and red 18" + cable to replace the black 36" cable 3 Share this post Link to post Share on other sites
Tuneup 1,452 #9842 Posted March 21, 2021 Just now, Tach-a-matic said: She's heavy now! What brand string trimmer is that, and do you like it? I need new one. . Wild Badger. The Poulan that was a hot mess of vibration and poor running was finally put aside. I gave it a good 15 years of my frustration. This is a 5 in 1 tool - trimmer, edger, brush cutter, hedge trimmer and chain saw. I've used all but the edger and chain saw and like it lots. Almost no vibration. Comes with a harness, too. You have to search hard for the 5:1. The 4:1 always comes up. Home Depot had the best ship to store price. I'm shopping a saw blade for it - will work better than that 4 blade cutter - got saplings to shred. 3 Share this post Link to post Share on other sites
Tuneup 1,452 #9843 Posted March 21, 2021 6 minutes ago, Tach-a-matic said: She's heavy now! What brand string trimmer is that, and do you like it? I need new one. . CNJ? I've got a mess of relatives in Somerset County... Share this post Link to post Share on other sites
Tach-a-matic 357 #9844 Posted March 21, 2021 I am in Somerset County as well, in Hillsborough Share this post Link to post Share on other sites
Tuneup 1,452 #9845 Posted March 21, 2021 3 minutes ago, Tach-a-matic said: I am in Somerset County as well, in Hillsborough Hey - really close! The farm is on Grouser Road. My grandparents, out of Raritan, used to take us to Dukes back in the day. Cousins down near Princeton. Great place to grow-up in the 60s and 70s. Sad to say, not a single Wheel Horse in any of our families - neighbor across the street had one... 1 Share this post Link to post Share on other sites
Tach-a-matic 357 #9846 Posted March 21, 2021 I just rode my bicycle to Dukes this afternoon! 1 Share this post Link to post Share on other sites
Jhook 849 #9847 Posted March 21, 2021 27 minutes ago, Tuneup said: Nice. That has burn pile written all over it! Ive had the burn barrel going for 4 days straight. Hopefully tomorrow is a good day to light the whole pile up 2 Share this post Link to post Share on other sites
haydendavid380 759 #9848 Posted March 21, 2021 (edited) My work bench was a little cluttered and a cluttered bench makes it difficult to work on horses. Wife said I might as well clean and organize the garage. Spent the afternoon on the garage and my bench now has more stuff on it than when I started. I'm convinced I can squeeze another tractor in there now though, so the jokes on her 🤣 Edited March 21, 2021 by haydendavid380 4 Share this post Link to post Share on other sites
The Tuul Crib 7,340 #9849 Posted March 21, 2021 Spent the day finishing up hook ups on the 12 horse. Should have it running tomorrow 8 1 Share this post Link to post Share on other sites
ashtonosborne2019 18 #9850 Posted March 21, 2021 is that the same motor as a sears suburban 12? Share this post Link to post Share on other sites
