ebinmaine 72,406 #9376 Posted February 20, 2021 33 minutes ago, Gregor said: I swapped the cardboard tube to an all weather plastic fishing rod holder Good addition but where's the rods now??? Share this post Link to post Share on other sites
Gregor 4,847 #9377 Posted February 20, 2021 I haven't flown with a fishing rod for 30 years. 1 Share this post Link to post Share on other sites
cschannuth 3,817 #9378 Posted February 21, 2021 I built a front bumper and weight rack similar to the one I have on my 606 today. I was so proud of myself for figuring out exactly how far outfront the weight needed to be to still allow the hood to open. However, when I went to install my bumper I forgot that the big block engine uses a J bolt a long side of the frame so I had to notch my new creation. It wasn’t that big a deal but it did aggravate me, ha ha. I also drilled a hole in the cross brace so that I can add a pin to drop between the plow frame rails to illuminate side to side blade deflection. I still need to finish that piece of it. 8 6 Share this post Link to post Share on other sites
haydendavid380 759 #9379 Posted February 21, 2021 9 hours ago, cschannuth said: I built a front bumper and weight rack similar to the one I have on my 606 today. I was so proud of myself for figuring out exactly how far outfront the weight needed to be to still allow the hood to open. However, when I went to install my bumper I forgot that the big block engine uses a J bolt a long side of the frame so I had to notch my new creation. It wasn’t that big a deal but it did aggravate me, ha ha. I also drilled a hole in the cross brace so that I can add a pin to drop between the plow frame rails to illuminate side to side blade deflection. I still need to finish that piece of it. Good grief that's a nice looking rig 👍 4 1 Share this post Link to post Share on other sites
Tractorhead 9,209 #9380 Posted February 21, 2021 Because of beginning springtime, i removed the Snowplow and mounted the Tiller. look if some wears can be found, but all sems fine so put it to it‘s new place and grabbed the Tiller. After an Oilchange i be curious if it‘s Engine will start and how many pull i need. I didn‘t expected that.. Ready for next weekend Fieldwork.👍 I love it if things going that Way. 6 2 Share this post Link to post Share on other sites
Tuneup 1,452 #9381 Posted February 21, 2021 (edited) Not quite springtime in Georgia USA as yet but it's warm enough to get seat time. I adjusted the 516 deck lift bolt and the brake according to procedure - still a bit looser than I'd like - and then took it out and lugged it around the yard with its 48" deck engaged to work on getting the rings sealed. I hate running low RPM on an automatic but I didn't climb anything steep. Best I could do. She ran like a champ and that Onan is a torque monster - a real keeper. Time to order a new brake lining... Budda-bing! One more rmaynard lining purchased... Edited February 21, 2021 by Tuneup 6 Share this post Link to post Share on other sites
Ed Kennell 41,787 #9382 Posted February 21, 2021 3 hours ago, Tractorhead said: beginning springtime Not on this side of the Pond. There's a garden someplace under there. 4 4 Share this post Link to post Share on other sites
OldWorkHorse 3,094 #9383 Posted February 21, 2021 Had some free time today so went down in the shop and messed around on the wheelhorse. Cleaned up some parts on the 1257Heavy project, and mounted the spacers on my 314-8 now the chains wont rub! 3 2 Share this post Link to post Share on other sites
johnnymag3 2,567 #9384 Posted February 21, 2021 Does this pushing out of the Wheel and Tire cause undo stress on the bearings? I know it does on cars and trucks, but Im unsure of what the bearing is doing when only the outer part of the bearing is seeing load and preload... ??????????????????? Thanks ???????????????? 1 Share this post Link to post Share on other sites
johnnymag3 2,567 #9385 Posted February 21, 2021 Tractorhead......what is the Oxygen sensor and wire for on that Machine?? Im curious John Share this post Link to post Share on other sites
Ed Kennell 41,787 #9386 Posted February 21, 2021 (edited) 10 minutes ago, johnnymag3 said: cause undo stress Undo stress ? It does increase the radial load on the bearing, but I doubt if it causes a bearing failure. Edit... Actually on rethinking, I don't believe the bearing load changes. The bending load on the axle does increase. Edited February 21, 2021 by Ed Kennell Share this post Link to post Share on other sites
johnnymag3 2,567 #9387 Posted February 21, 2021 (edited) 49 minutes ago, Ed Kennell said: Undo stress ? It does increase the radial load on the bearing, but I doubt if it causes a bearing failure. Over time, it has to have an effect on the bearing....as It was made to be loaded in the center of its entire width, correct?? Or doesn it matter beacause its not going to do 25,000 miles at 55 MPH...... Just wondering as a guy who often dealt with stress and function, plasigauge in many applications... Edited February 21, 2021 by johnnymag3 Share this post Link to post Share on other sites
OldWorkHorse 3,094 #9388 Posted February 21, 2021 Also mocked up the 1257Heavy 4 3 Share this post Link to post Share on other sites
OldWorkHorse 3,094 #9389 Posted February 21, 2021 1 hour ago, johnnymag3 said: Does this pushing out of the Wheel and Tire cause undo stress on the bearings? I know it does on cars and trucks, but Im unsure of what the bearing is doing when only the outer part of the bearing is seeing load and preload... ??????????????????? Thanks ???????????????? Probly adds some but nothing critical photos make it look alot more out then they are. 2 Share this post Link to post Share on other sites
ebinmaine 72,406 #9390 Posted February 21, 2021 @OldWorkHorse That's lookin gooood!! 1 Share this post Link to post Share on other sites
ebinmaine 72,406 #9391 Posted February 21, 2021 3 hours ago, johnnymag3 said: Does this pushing out of the Wheel and Tire cause undo stress on the bearings? Are we talking because of the spacers? I've had 3" spacers on Cinnamon Horse until recently. I removed them to put them on Colossus. The C160 now has 2" spacers. They're needed because I have "other brand" wheels with the wrong back spacing. 1 1 Share this post Link to post Share on other sites
Horse Newbie 7,395 #9392 Posted February 22, 2021 5 hours ago, OldWorkHorse said: Also mocked up the 1257Heavy Just my humble opinion, but I would probably add some braces on those legs on that rolling table... 1 Share this post Link to post Share on other sites
OldWorkHorse 3,094 #9393 Posted February 22, 2021 (edited) 1 hour ago, Horse Newbie said: Just my humble opinion, but I would probably add some braces on those legs on that rolling Shes stronger then she looks. Just my set a part on it and grind the rust off it table. It's all taken apart now just used it for getting the old grease and dirt off the parts didnt feel like bending over on the floor Edited February 22, 2021 by OldWorkHorse 2 Share this post Link to post Share on other sites
TJ5208 1,841 #9394 Posted February 22, 2021 Well I did see what duals would look like on my tractor I think they look good and the exhaust sounds awesome check out my video at tj salyers on you tube first video 2 Share this post Link to post Share on other sites
TJ5208 1,841 #9395 Posted February 22, 2021 I just took the tire off of the other side and put it by this side so I can see what it would look like 1 Share this post Link to post Share on other sites
OldWorkHorse 3,094 #9396 Posted February 22, 2021 6 minutes ago, Tj salyers said: I just took the tire off of the other side and put it by this side so I can see what it would look like Honestly its your tractor and if I had the stuff to do it I'd run duals. Ull probly b able to pull just as much as u were b4 and the cool factor goes way up. Thos spacers for 12 inch rims been on flea bay all the time pretty cheap just a I belive metal collar that sets in lip of rim then u sent long bolt though and keeps the spaced and not able to shift around when hit stuff like rocks or bumps. 1 Share this post Link to post Share on other sites
TJ5208 1,841 #9397 Posted February 22, 2021 Thank you for the help Stevebo Im thinking about running now 1 Share this post Link to post Share on other sites
OldWorkHorse 3,094 #9398 Posted February 22, 2021 31 minutes ago, Tj salyers said: video at tj salyers on you tube first video She sounds prrrrdyy! Nice tractor man! 1 Share this post Link to post Share on other sites
TJ5208 1,841 #9399 Posted February 22, 2021 Can you subscribe thanks he's a nice tractor I'm thinking about taking the Raider 10 and putting the six-speed and then do you have a Raider 10 if you do can you send me some pictures on how the transmission mounts Share this post Link to post Share on other sites
OldWorkHorse 3,094 #9400 Posted February 22, 2021 I only have a 1257 and a 314 and atm the 1257 is missing the trans. You should b able to find some threads on this site that would b able to answer most of your questions. Hows I've solved 90% of mine. Share this post Link to post Share on other sites
