Jhook 849 #8301 Posted December 24, 2020 Got my rear weight setup for the charger 12 loader from work today. These drums weigh 110 a piece. They fit tightly inside eachother as shown. The bottom one will bolted to the loader frame behind the axle, then i can add the top drum for extra weight as needed. I can also fit a fairly large bucket of concrete inside them as well. Should work good and cant be the price of free 8 2 Share this post Link to post Share on other sites
ebinmaine 75,781 #8302 Posted December 24, 2020 25 minutes ago, Jhook said: cant be the price of free One of my favorite 4 letter words!! 5 Share this post Link to post Share on other sites
Jhook 849 #8303 Posted December 26, 2020 Girlfriend is catching on! Got me this sweatshirt for christmas. Hope every one had a good holiday and enjoy the long weekend👍 2 5 2 Share this post Link to post Share on other sites
DennisThornton 4,772 #8304 Posted December 26, 2020 48 minutes ago, Jhook said: Girlfriend is catching on! Got me this sweatshirt for christmas. Hope every one had a good holiday and enjoy the long weekend👍 Can't say I've been a good judge, but you just may have a "Keeper"! 1 1 1 Share this post Link to post Share on other sites
ebinmaine 75,781 #8305 Posted December 26, 2020 Been working on Trina's Pigpen 867 a little the last month or so. The starter/generator has needed a bearing replaced for a looong time so I got that done. Replaced both bearings and cleaned it up some inside. Brushes were fine. Changed the engine oil. Last night I started adding a light circuit to it. Had headlights originally. I've ordered replacement sockets for the stock headlamp setup. I'll be adding some 3/4" white LEDs at the back and a small set off 2" round black LEDs at the front on magnetic bases that'll point out at forward left and right angles. 6 1 1 Share this post Link to post Share on other sites
Shynon 7,505 #8306 Posted December 26, 2020 (edited) Loader swap done. 522xi with power steering oopd forgot the front tires Edited December 26, 2020 by Shynon 6 4 Share this post Link to post Share on other sites
Jhook 849 #8307 Posted December 26, 2020 Got the subframe built up for the charger loader today. This little harbor freight welder seems to do great with 3/16 thick tubing. I am still learning how to weld. Never been taught and the only time i gain experience is when i need to build or fix things. I think im doing it right lol 14 1 Share this post Link to post Share on other sites
pfrederi 19,278 #8308 Posted December 26, 2020 Pulled the head on a non-running K301 I picked up a couple years ago. Big reveal always wonder what the piston will be stamped. STD .010 OK .030 parts pile...Had to clean off some carbon for the big reveal .003 cylinder wall looks good. This one will get stripped down and off to the machine shop for bore and grind... 11 Share this post Link to post Share on other sites
ebinmaine 75,781 #8309 Posted December 26, 2020 52 minutes ago, pfrederi said: Pulled the head on a non-running K301 I picked up a couple years ago. Big reveal always wonder what the piston will be stamped. STD .010 OK .030 parts pile...Had to clean off some carbon for the big reveal .003 cylinder wall looks good. This one will get stripped down and off to the machine shop for bore and grind... Got that rare extra ventilated engine shroud Paul? 1 Share this post Link to post Share on other sites
rjg854 12,636 #8310 Posted December 26, 2020 Shroud is looking mighty rough, you gonna replace it or can you fix it? 1 Share this post Link to post Share on other sites
pfrederi 19,278 #8311 Posted December 26, 2020 6 minutes ago, rjg854 said: Shroud is looking mighty rough, you gonna replace it or can you fix it? Replace...Painting and body work are not my hobbies.... I only do things I enjoy 2 3 1 Share this post Link to post Share on other sites
pfrederi 19,278 #8312 Posted December 26, 2020 24 minutes ago, ebinmaine said: Got that rare extra ventilated engine shroud Paul? As I said no body work...maybe some duct tape??? 1 3 Share this post Link to post Share on other sites
Jhook 849 #8313 Posted December 26, 2020 Well i tried to start the charger and bring it up to my driveway to install the subframe, but it wont start. I ran it after the snowstorm for about 20 mins and it ended up running out of fuel. It was running very rich making lots of black smoke for a few mins the other day. Now i filled the tank and it wont start at all. It fired a few times but never fully started and ive gone thru 2 fully charged batterys. I tried starting fluid too and it worked its way out the exhaust without starting. Is there a normal priming procedure after you run these out of fuel? Its a k301s engine. I will verify spark tomorrow but don't see why that would be an issue as i drove it the other day. 1 Share this post Link to post Share on other sites
pfrederi 19,278 #8314 Posted December 26, 2020 (edited) If starting fluid is coming out the exhaust you have flooding issue or spark issue. Pull the plug is it wet??? A charger could have one of three ignition systems which does yours have , Battery, Magneto or Breakerless Edited December 26, 2020 by pfrederi Share this post Link to post Share on other sites
adsm08 3,871 #8315 Posted December 26, 2020 On 2/17/2018 at 8:24 PM, 953 nut said: Could be a wire came loose from the PTO or seat switch while traveling, Clean and tighten all the connections one at a time and it should be OK. Over the summer my neighbor was using his XD series JD, turned a corner, and it died. We could jumper power to the starter and get it to start, but it would die as soon as you turned the blades on. Stupid seat switch had plumb fallen out of the seat. Share this post Link to post Share on other sites
Jhook 849 #8316 Posted December 26, 2020 39 minutes ago, pfrederi said: If starting fluid is coming out the exhaust you have flooding issue or spark issue. Pull the plug is it wet??? A charger could have one of three ignition systems which does yours have , Battery, Magneto or Breakerless I am not sure which ignition system it has. I will get numbers off the engine tomorrow and follow up. Also with change the plug and throw an in line spark tester on it. I really didnt feel like taking the carb off it today it was getting dark so i just left it and will check everything tomorrow starting with the easy stuff. I know for a fact the machine does not charge the battery although that could be a ground issue. Dont know enough about these engines to dig into that issue yet. I just keep a charged battery on hand and itll start 5-10 times Share this post Link to post Share on other sites
Maxwell-8 4,370 #8317 Posted December 27, 2020 (edited) 14 hours ago, ebinmaine said: Been working on Trina's Pigpen 867 a little the last month or so. The starter/generator has needed a bearing replaced for a looong time so I got that done. Replaced both bearings and cleaned it up some inside. Brushes were fine. Changed the engine oil. Last night I started adding a light circuit to it. Had headlights originally. I've ordered replacement sockets for the stock headlamp setup. I'll be adding some 3/4" white LEDs at the back and a small set off 2" round black LEDs at the front on magnetic bases that'll point out at forward left and right angles. That's how clamp-connections shoud be made! Edited December 27, 2020 by Maxwell-8 Correcting autocorrection 1 1 Share this post Link to post Share on other sites
ohiofarmer 3,383 #8318 Posted December 27, 2020 (edited) Just like pfrederi, I pulled the head off my main worker. it had been running great, but i noticed that the spark plug did not want to thread back in. Bot wanting to risk cross thread, time to pull that head. The piston was stamped 235802. That is not a Kohler number. I tried to reference it ,and it probably is a standard size. In my seat of the pants shade tree hillbilly bore evaluation, i used a thickness gauge, and it fit consistently around the piston from the top of the bore all the way down on all sides the same and top to bottom. That's without any disassembly But that spark plug thread still needs to be chased, so we will be shut down for putting it back together. Anybody know the thread size for a spark plug tap?? Stens 750810 ?? Edited December 27, 2020 by ohiofarmer Share this post Link to post Share on other sites
JohnD 145 #8319 Posted December 27, 2020 I was surprised to learn that spark plugs in the USA have been metric thread for many years. My KT-17 head has a 14mm x 1.25mm plug thread. Here's Champion's descriptions of their threads: https://www.championautoparts.com/Technical/Tech-Tips/decoding-champion-spark-plugs.html 1 Share this post Link to post Share on other sites
Horse Newbie 7,398 #8320 Posted December 27, 2020 Got my freshly powder coated wheels put on the 520 H today...new bearings and seals on front, two new front tires. 3 3 Share this post Link to post Share on other sites
76c12091520h 4,003 #8321 Posted December 27, 2020 Finished cleaning the overspray from the front tires and the rear wheel bolts for the 854. Front tires look absolutely like new, and whoever did the crappy rattle can paint job did me a huge favor because there was some perfectly preserved bolts under that cheap paint! 6 1 Share this post Link to post Share on other sites
19richie66 17,769 #8322 Posted December 27, 2020 16 hours ago, Jhook said: Got the subframe built up for the charger loader today. This little harbor freight welder seems to do great with 3/16 thick tubing. I am still learning how to weld. Never been taught and the only time i gain experience is when i need to build or fix things. I think im doing it right lol Looks good to me. Can that welder be converted to gas and solid wire? It would be much cleaner. 3 Share this post Link to post Share on other sites
ebinmaine 75,781 #8323 Posted December 27, 2020 14 hours ago, ohiofarmer said: Just like pfrederi, I pulled the head off my main worker. it had been running great, but i noticed that the spark plug did not want to thread back in. Bot wanting to risk cross thread, time to pull that head. The piston was stamped 235802. That is not a Kohler number. I tried to reference it ,and it probably is a standard size. In my seat of the pants shade tree hillbilly bore evaluation, i used a thickness gauge, and it fit consistently around the piston from the top of the bore all the way down on all sides the same and top to bottom. That's without any disassembly But that spark plug thread still needs to be chased, so we will be shut down for putting it back together. Anybody know the thread size for a spark plug tap?? Stens 750810 ?? 14 MM?? Share this post Link to post Share on other sites
WVHillbilly520H 10,377 #8324 Posted December 27, 2020 19 hours ago, Jhook said: Got the subframe built up for the charger loader today. This little harbor freight welder seems to do great with 3/16 thick tubing. I am still learning how to weld. Never been taught and the only time i gain experience is when i need to build or fix things. I think im doing it right lol You are doing fine, a chipping hammer and wire brush would help clean those up, also if you did go with gas and used flux core wire the welder weld would be stronger than either style alone just a little tip for future reference. 4 Share this post Link to post Share on other sites
cleat 8,101 #8325 Posted December 27, 2020 28 minutes ago, ebinmaine said: 14 MM?? Another good reason to have that 14mm tap on hand is that a lot of oxygen sensors use that same thread. Handy to have the tap at hand if / when you need to change out an o2 sensor in your car. 5 Share this post Link to post Share on other sites
