echris 1,426 #7976 Posted November 28, 2020 47 minutes ago, Jhook said: New idler pulley today from tractor supply. I have the toro part on order but need the machine moveable this weekend. Bought a new 5/8x84 belt as well. Thats what came off the tractor not sure if its original size as the motors been swapped. Well when the toro pulley arrives i may swap it on but i will try the tsc pulley, itll be nice to know if parts i can buy in store 5 mins away work well or not. It's handy having a local place where you can at least find generic parts. I do the same when I need something quick if I can find it local, and then order the OEM for backup. A crappy $5 idler that get's you back to work is usually worth it. As long as it's a quick change. Sometimes you get lucky and the crappy $5 idler is quite nice. You might wanna order that return spring too. She looks like she's about to get all boingy in the wrong direction. 2 1 Share this post Link to post Share on other sites
Jhook 849 #7977 Posted November 28, 2020 11 minutes ago, echris said: It's handy having a local place where you can at least find generic parts. I do the same when I need something quick if I can find it local, and then order the OEM for backup. A crappy $5 idler that get's you back to work is usually worth it. As long as it's a quick change. Sometimes you get lucky and the crappy $5 idler is quite nice. You might wanna order that return spring too. She looks like she's about to get all boingy in the wrong direction. I should have grabbed one while i was there. I looked right at em then assured myself i had everything i needed. They still haven't restocked from a week ago when i cleaned them out of clevis pins. Need 4 more for the loader still Share this post Link to post Share on other sites
Jhook 849 #7978 Posted November 28, 2020 Also sold the snow cab today. Never got around to mounting it to the 315 and dont have time now that i have the charger loader project. Paid 125 and spent 60 on vinyl and an hour of labor replacing 2 windows. Sold it for 250 and im happy, more importantly the buyer was happy and is probably at home now throwing it on his c121 or whatever model he had. 2 Share this post Link to post Share on other sites
Jhook 849 #7979 Posted November 28, 2020 Loading the rear tires now for the charger👍 1 1 Share this post Link to post Share on other sites
Lee1977 7,638 #7981 Posted November 28, 2020 Fixed a flat tire on my 312 couldn't find a thing wrong with the tire but the tube had a hole in it. Pulled it off and patched the tube. Took longer then it should have looking for the patches and glue. Getting it back on gave me a little trouble but once I clamped a small set of vice-grips on the edge of the rim it went back on. Those little 400 x 8 4 ply Triribs are stiff and the 3" rims don't help any either. 3 Share this post Link to post Share on other sites
Rob R 989 #7982 Posted November 29, 2020 (edited) Yup they can get stiff with age and cold weather next time use a heat gun to heat the side walls makes a big difference..... just saying........p.s. I also use a Vice grip pliers to hold the started bead. Edited November 29, 2020 by Rob R 3 Share this post Link to post Share on other sites
ebinmaine 79,099 #7983 Posted November 29, 2020 7 minutes ago, Rob R said: next time use a heat gun to heat the side walls Blow-dryer works well too. Also usable and high functioning (but somewhat risky) is to have the swmbo get to talking about her favorite subject then hold the tire/wheel up to her face. Voluminous volumes of hot air exiting the area will quickly bring the tire to a pliable temp. On particularly stubborn or very old tires one can get the speaker angry first Then repeat the first step. 5 Share this post Link to post Share on other sites
SylvanLakeWH 31,517 #7984 Posted November 29, 2020 44 minutes ago, ebinmaine said: Also usable and high functioning (but somewhat risky) is to have the swmbo get to talking about her favorite subject then hold the tire/wheel up to her face. Voluminous volumes of hot air exiting the area will quickly bring the tire to a pliable temp. On particularly stubborn or very old tires one can get the speaker angry first Then repeat the first step. Oh...be... afraid...very...afraid... Brave man or very very uhm... cranially challenged...? 2 Share this post Link to post Share on other sites
ebinmaine 79,099 #7985 Posted November 29, 2020 6 minutes ago, SylvanLakeWH said: Brave man or very very uhm... cranially challenged I am only one of these. It isn't brave. 1 Share this post Link to post Share on other sites
R Scheer 515 #7986 Posted November 29, 2020 1 hour ago, ebinmaine said: Blow-dryer works well too. Also usable and high functioning (but somewhat risky) is to have the swmbo get to talking about her favorite subject then hold the tire/wheel up to her face. Voluminous volumes of hot air exiting the area will quickly bring the tire to a pliable temp. On particularly stubborn or very old tires one can get the speaker angry first Then repeat the first step. I suspect using this method you won't be worrying about a flat tire, you may not be worrying about anything else either. 2 Share this post Link to post Share on other sites
Lee1977 7,638 #7987 Posted November 29, 2020 (edited) Work it, but buy a few more so you can keep it nice. I had only one for 37 years. It's still a nice tractor has a few small dents been painted once, most of the original decals are still there. All of the bearings have been changed once and some twice. Oilite bushings have been added to the PTO shaft and the clutch. The axle pivot has been rebuilt, tie rods replaced wit heims joints, has trailer wheels and spindles. The engine has been replaced twice. It's not a collector's tractor It's a worker. It still mows not as often now that I have three with decks. I has vacuum attach set-up so it gets that job. Edited November 30, 2020 by Lee1977 6 Share this post Link to post Share on other sites
19richie66 17,892 #7988 Posted November 29, 2020 Nice Lee! Share this post Link to post Share on other sites
Jhook 849 #7989 Posted November 29, 2020 Trans passes the test i believe, pulled it up against a tree after warm up and it spun the tire with me on it, liquid ballast, and a 50 pound wheel weight. The parking brake shaft is ziptied in the down position until i get the opportunity to split the trans. But i cant have this thing in the driveway and just let it sit. I had to have some fun with it so played around for about 30 mins today in the yard, mainly testing the loader out. It has all new pins now which are nice and tight but it appears that im going to need a new hydraulic pump. I have been looking at a "2.9gpm/2000 rpm(rated)-5.2gpm/3600 rpm(max)" pump. Other than that i see some lines blowing in the near future and the subframe is on the to do list as well. Happy with the machine and still should be under 1700 bucks all said and done. The kohler k301s seems to run good and has nice clean oil in it. I like the old engine just as much as the CH15S in my 2007! 20201129_162336.mp4 2 2 Share this post Link to post Share on other sites
ebinmaine 79,099 #7990 Posted November 29, 2020 4 minutes ago, Jhook said: new hydraulic pump Where is the pump? Separate from the transmission? Share this post Link to post Share on other sites
Jhook 849 #7991 Posted November 29, 2020 1 minute ago, ebinmaine said: Where is the pump? Separate from the transmission? The hydraulic pump for the loader. Its mounted to the loader frame amd driven by the engines pto 2 Share this post Link to post Share on other sites
ebinmaine 79,099 #7992 Posted November 29, 2020 1 minute ago, Jhook said: The hydraulic pump for the loader. Its mounted to the loader frame amd driven by the engines pto Ahh. Never seen one up close so I figured it was powered by the transmission fluid pump. Share this post Link to post Share on other sites
rmaynard 17,208 #7993 Posted November 29, 2020 I got a little attachment to pull around in the spring. 4 Share this post Link to post Share on other sites
Jhook 849 #7994 Posted November 29, 2020 7 minutes ago, ebinmaine said: Ahh. Never seen one up close so I figured it was powered by the transmission fluid pump. Heres the setup, note the welds are not mine and the fab work is not mine. Mine would look professional compared to this and im not too great honestly 1 Share this post Link to post Share on other sites
Herder 2,356 #7995 Posted November 29, 2020 6 minutes ago, ebinmaine said: Ahh. Never seen one up close so I figured it was powered by the transmission fluid pump. The pump on the 1054 is mounted in front of the right foot rest and is run off the PTO 2 Share this post Link to post Share on other sites
Jhook 849 #7996 Posted November 29, 2020 1 minute ago, Herder said: The pump on the 1054 is mounted in front of the right foot rest and is run off the PTO That looks wicked nice. I like the loader and the machine. Looks like the same johnson that i have? Just not nearly as used 2 1 Share this post Link to post Share on other sites
Tractorhead 9,217 #7997 Posted November 29, 2020 If it‘s not leaking, what is the reason for a new Pump? do you know the Lift Force how much it can lift? Normally on a Hydraulics is somewhere a filter in, mostly in return or the suction line. if that filter clogged, your hydraulic pump wasn‘t able to suck enough oil to lift the Load, if it‘s able to lift 200 pounds i see no need for a new Pump. To see what happen on the hydraulic Side, you can add an T with an Hydraulic pressure gauge on the intake line on the Valves. the oilflow just give you an indicator how fast your hydraulic can work, but not really how strong it is. Therefore lot‘s of hydraulic Valveblocks have a additional adjustable pressure restriction valve in parallel. If the hydraulic pressure exceeds the preinstalled value, a bypass opened and reduces the hydraulic pressure to the adjusted limit. 1 Share this post Link to post Share on other sites
Jhook 849 #7998 Posted November 29, 2020 4 minutes ago, Tractorhead said: If it‘s not leaking, what is the reason for a new Pump? do you know the Lift Force how much it can lift? Normally on a Hydraulics is somewhere a filter in, mostly in return or the suction line. if that filter clogged, your hydraulic pump wasn‘t able to suck enough oil to lift the Load, if it‘s able to lift 200 pounds i see no need for a new Pump. To see what happen on the hydraulic Side, you can add an T with an Hydraulic pressure gauge on the intake line on the Valves. the oilflow just give you an indicator how fast your hydraulic can work, but not really how strong it is. Therefore lot‘s of hydraulic Valveblocks have a additional adjustable pressure restriction valve in parallel. If the hydraulic pressure exceeds the preinstalled value, a bypass opened and reduces the hydraulic pressure to the adjusted limit. The pump leaked a few ounces of fluid on a short drive down the hill. The tire was completely covered and pump was dripping. Stopped and check fluid level, its over half full so that's fine. Didnt leak any more after that at all. Not sure why. Also the pump bracket is welded in crooked putting stress on the shaft. It is all wet around the shaft. Thoughts on this one? Share this post Link to post Share on other sites
ebinmaine 79,099 #7999 Posted November 29, 2020 7 minutes ago, Jhook said: Didnt leak any more after that at all. Not sure why Before you spend good money after bad, figure out where the actual problem is. If you remove the pump and garbage bracket you may be able to put a seal kit in it and remount the whole assembly. 2 Share this post Link to post Share on other sites
Jhook 849 #8000 Posted November 29, 2020 2 minutes ago, ebinmaine said: Before you spend good money after bad, figure out where the actual problem is. If you remove the pump and garbage bracket you may be able to put a seal kit in it and remount the whole assembly. The pump in it has a shaft smaller than 1/2 inch which is not up to par for the application. 1/2 inch or smaller shaft needs to be direct driven. It doesnt have the strength to handle the side-load that gets put on it when it's run by a belt. So even if i did re seal it, id have to take it off in a few hours anyways cause its not designed to be used this way. The pulley is welded crooked to the shaft also😂 i wish i got the machine as a basket case i could have assembled it much nicer 1 Share this post Link to post Share on other sites
